Nope, it's right where it should be. I unhooked the trailer to lift the Spyder. You see a cap that's off but miss the big freaking fender I added. You really need to get out more ;)
Printable View
Just checked on this and looks like they are still doing free shipping, so very cool. :thumbup:
Course that means I need to make room for it...anybody in the H-town area want to buy a used HF m/c lift for cheep?
Guess I'll be putting up a post in the FS forum cause if I don't get rid of this one first, the wife will be all :lecturef_smilie: and we don't want that.
3 more friends....:pray:
I would expect pallet jack or a few dolley's
thats ok, rented a fork lift to get it up drive way after delivery truck drops it with lift gate. owner of rentals will send a manual lift as well to position it after its in garage. :clap: Owner of rental co. told me he will make sure its put exactly where I want it...very nice man.:yes:
I unloaded my direct lift table on to a small utility trailer from the semi. Then pulled that into my driveway and backed in to my shop.
Thinking of a two post lift. Also good for auto/truck and you can stand under while working under. Yes I do have the room.
Jack
Here's some pics of my Black Widow motorcycle lift modification to lift my Spyder. Two 1" black pipes hold the wood extensions. I had to put the front extension on the lift to fit the Spyder. I open the tire jaw all the way and the Spyder rear tire fits in.
It looks like a sensor or a vent for whatever is above it. I haven't had my Spyder apart yet to recognize it. I do have the Shop Manual on a disk. i'll look it up for you. Sorry, I couldn't find it. Does your Spyder have Automatic AirBag and compressor? If it does, that piece might be the Pressure Relief Muffler. My best guess. Try lowering the Airbag pressure by the switch and listen for and feel if air is coming out of the thing-a-ma-jig.
I have a 4 post car lift with a jack lift and a scissor car lift. Advantage of getting a car scissor lift is you can work on your car tires brakes etc easier. A little more expense but a lot more useable. I just built a wooden table I put on the scissor lift. It makes a super work area also when I need a bigger table and when I don't need it I simple remover the top.
