Spyder Newb. 2009 GS SE5 for wife. 21k miles. Clean, two owner machine. Oh boy!!
So I'll be handling the maintenance on this bad boy and just had a few questions for the group. I've been riding and wrenching on bikes for quite a long time but this thing is a little different to say the least!
1. Belt tension? I purchased a Gates Cricket and am looking for an answer on what the tension should be when using the tool.
2. Rear tire opinions? The Kenda needs replacing. I've read that their are a few automotive tires that work just as good, if not better than the Kenda at a much lower price point. I'm open to suggestions....
3. Oil changes. Just buy the Can Am kit or is there better, less expensive options?
4. Any "gotcha's" to be looking out for with these bikes? I had an '02 Aprilia RSV Mille that had essentially the same engine as this. I know they are pretty hard to kill. The belt drive, "automatic" transmission, and front end suspension/alignment are going to be the "learn as I go" stuff.
5. Smaller riders...My wife is 5'1" on a good day. I already have a set of RIVCO bar risers on order. Anything else I can do to get the bike better suited to her size? Peg adjustments? Floorboards? Seats?
I'm sure I'll be able to find a lot of this info while I continue to search the forums but just wanted to reach out, say hi, and pick folks brains while I was at it.
LJ Allen
1 Attachment(s)
Search the forums for problems seen!
My wifes byke is a 2008GS (same as yours).
Search BRP notices & recalls!
1. Front sprocket. Keep an eye on it for red dust. "common" problem is the teeth wear out or the bolt gets loose. A friends' 2009 just stopped on the road, the bolt snapped! Torque should be 115ft lbs. cheapcycleparts.com has the bolt & sprocket cheap.
2. Gear Box Position Sensor (GBPS). Can search for this here too. Another common thing is sticking in gear, or trans light flashing. This sensor gives a 0V to 5V signal back to the computer on what gear it is in. It is a cheaply made part that goes bad on a lot of bikes. This sensor is behind the front pulley.
3. Oil in air box. Very common. Search it here. Several posts on a quick fix with a check valve. Over time oil gets sucked up into the air box.
4. Should be about 1/8" to 1/16' between the belt edge and the pulley wall on rear sprocket. I've noticed two bikes in our group where
the edge was rubbing a little. That belt is $$.
5. Oil level is critical. Check with warm engine. Too little and the tranny will act up.
6. There was a tech bulletin about grounding the coil pack. Its on left side. If not there, run a wire from the coil frame to a good ground nearby. The electrical noise can cause random weirdness with the trans computer CanBus communications.
7. BRP parts for 2008-2010 GS/RS are cheap on EBay. I got rims for $115 shipped! Picked up a rear seat cowl cheap.
When working on the belt, front pulley, replacing the GBPS, etc. use the shock bolt to get belt off. Take off the lower shock bolt nut (13mm). Slowly jack up about midway on the bike on the center frame. The rear A-Frame will reach a point where the bolt will slide right out. Then keep jacking until the belt is loose. This way you will not mess with the rear tire adjustments.
I have the PDF shop manual, I can send if you give PM me an email address.
Steve
