I do not like the usb plug for BRP Connect in the frunk. Has anyone came up with a way to move it?
Printable View
With a USB extension cable you can move it anywhere you would like. Just connect the extension cable and route it to the location of your choosing.
I used the extension cable Lamonster sells to mount the phone on top of the RT dash. I routed the cable up thru the center windshield mount. I use a TricLED dash bracket and RAM X-Grip and I find it way easier to access and get to along with it being a lot cooler with air flow compared to stuck in the frunk.
Brand new to the spyder. Would you have to remove any panels to route a USB extension thru the middle windshield frame?Thanks for any help.
Yes there are a few panels to remove to get access to behind the headlight. The panel in the frunk so you can route the cable thru it and up under the headlight. Then the mirrors, side panels and headlight frame piece as well as one of the headlights.
Unless you know how to use an electricians fishing wire and can get it where you need to to get the phone cable.
There are videos on YouTube showing how to remove the panels. A little tricky at first but gets easier after doing it a few times. Canammanuals.com is where you can buy a service manual to help.
Flamewinger , can you post a pic of your mount location???
Thanks
Joe
I use the RT Dash bracket to mount the phone with RAM components. I use the older iPhone to connect to the dash system. I use my current phone or music, Garmin, Waze and SiriusXM and I mount it to the center of the handlebars with RAM Ball parts.
Here is the good and the bad.
I ran a USB cable from the handle bars to the frunk and it did not sink correctly all the time.
I pulled the factory USB cable from the frunk up to the dash and ran in through the handle bar hole.
It works a whole lot better.
There are only a couple wire ties that you will need to cut.
I just removed the black access cover under the frunk lid.
Hey Johndeeredoo,
I just got a new Can-Am so I'm new at this and don't know all the ins and outs of the BRP Connect yet but
I think that I want both the BRP activated USB cable on the handle bars and also want to be able to charge and go bluetooth wireless. It seems like if I connect that cable I can no longer just use any old GPS or stream my music. Its like it disables the bluetooth. I have to power it by some other means because the BRP Connect app takes over on the phone. I want to be able to do both maybe. I haven't yet completely dumped the BRP connect but it seems somewhat ludicrous so maybe this is a moot point but I want to get a handlebar mount and route a cable to power the phone and maybe also the BRP cable. Does this make any sense? I also want to have an SAE connector nearby for my trickle charger and heated gear.
So the things I want are:
1) Power Heated Gear
2) Trickle charger
3) Power Phone
4) Use BRP Connect (unless I dump it which seems ashame)
The lamaster mount has USB that you tie into the battery or the aux. It is a cigarette lighter plug so I could trickle charge after getting off and pulling the phone out but if I have heated gear I'd want an SAE connector anyway.
Because I have an SAE to coax dongle and the SAE would be a standard that could have anything even a USB connect up to it.
So it seems like I'll need to route an SAE connector probably under the seat to pull out for the heated gear.
I could actually put a Y connector on that and power the phone but that still doesn't solve the BRP Connect USB issue.
So, anyone have any idea of what they would do to have all of this functionality or is the BRP connect as bad as it seems and I should dump it if I'm going to mount my phone anyway.
I just can't see putting my phone in the frunk and have to pull it out every time I want to make a change.
So
I ran a 6' USB-Lightning extension from the frunk connector, under the front panels and into the glove box on my '18 RT-L. Drilled a small hole in the frunk side wall and a teeny hole in the side of the glove box. Works perfectly, and I can now either use BRP Connect, or put my iPhone X Max on the handlebar RAM mount and use it directly. Took me about an hour for the whole thing. You do have to remove the mirror and side panels for best access.
If you run the extension through the glove box, doesn't the glove box have to be open/ajar when using the phone with the extension?
Nope, the glove box closes fine with the cord running out the top edge. Probably isn't a water-proof seal, but. hey, I don't ride in the rain!
I have a 2018 F3 Limited, and I have installed a RAM Mount on my handlebars right next to my left hand grip. This setup works great when I connect my phone directly to my Schuberth helmet (via bluetooth). However, I need to connect my phone to the BRP connect USB cable in the front glove box to use that functionality, but I would really like to do both on an as needed basis.
I have seen a number of posts from RT owners about how they have routed their BRP Connect USB cable through the glove box and out to the handlebars, but is there possibly an F3 Limited owner out there that can help me figure out a clean way to route the cable from the glove box on my F3 up to the RAM mount I have installed on my handle bars?
It would have been great if the glove box had a small opening available (even when closed) to route a cable out of the box, but the need for water protection in the glove box makes that impractical.
Any suggestions/help with this issue would be sincerely appreciated. Thanks!
