JT Motorsport Frederick MD.
JT MotorSport In Frederick Maryland is a fairly new Can Am Dealer (just in the last say 18 months). I needed some seals for the rear axel on my 2012 Spyder RTL that I'm changing the rear tire on so I thought now would be a good time to check them out. I looked on the web site and it said they had S2S in stock and some RTLs in stock and F3L in stock and Rykers in stock. It also said that they do laser alignment., tire changes, oil and all other repair work services. This dealer is 38 miles form my home and the dealer that I would normally go to is MotorSports Cycle Shop in Hanover PA. it is 43 miles away from my home. So off I went to JT Motoersports, I found the place easy and went in with the wife to look at the Spyders before I get the parts I need. Once I got in the door there were only 3 Spyder in there all were gray F3L all the same nothing else. There were a lot of two wheelers dirt bike and some street bikes and accessories. So I just went to the far end of the store where the part counter was and asked for the parts I needed, I gave the young man a list with two part numbers and name of part i.e. o ring the other was a seal. I told him it was for a 2012 Can Am Spyder RTL. He tried to pull the numbers up in his system it took him ten minutes (felt like an hour) he said he was having trouble with the system. So while waiting for the system to reboot I asked him if they did laser alignments and he told me he did not think so that they did not have the tools yet but he could go back and ask the service guys I said please do and ask how much it will cost also. So he went back and asked when he came back he said that yes they do, do Laser Alignment and that it would cost $189.99 and maybe a little more if they needed to use shims or something like that (it made no sense to me). So he got his computer running and got the part numbers in he said he would have to order the parts I wanted and they would be in next week. I said never mind and that you should have that stuff on hand because every time you change a rear tire you should replace them parts.
So I left and went to my normal place Motorsports Cycle Shop in Hanover PA. Looked at the S2S there and RTL and F3L asked for the parts I needed I gave the man the list with the part numbers and before I could tell him what it was he knew and said Let me get them for you, two minutes he was back with the parts and I asked him about doing a Laser Alignment (I know they do lots of them) He said I could call any time to set up a time to get it done and it would cost $125.00.
REVIEW: JT Motorsports in Frederick :dontknow: I will let you be the judge, I will not go back they don't have a clue. Maybe with a few years of experience they will get better.
