Headlights coming on when bike is off
I have had my 2008 Spyder SM5 for almost 6 years. I have been more than pleased with it's service. However, last night we had a major storm pass through and it brought a lightning storm that created quite a light show. I haven't ridden in in about a week and the keys were in the house. Because of the strong winds, I went around making sure the rain wasn't blowing in. As I checked the window that offers a view of the Syder I noticed the area was lit up. Initially I though someone had arrived but realized that the headlights of the Spyder had come on. Although the rain was major I decided to go out and turn it on and off hoping to reset whatever had been triggered, by most likely a magnetic impulse from one of the closer lightning strikes. That didn't do anything, I then started it and ran it for a minute and shut it off, while that didn't shut off the headlights the dash lights that had also been on went off. I decided to let it be and see if it would reset on its' own because of the deluge. But after a couple minutes put on some better weather protection I went out and popped the trunk and pulled the headlight relay hoping that would prevent the battery from draining. The headlights, of course, went out but this morning the battery was completely drained. I called the local dealer and they had never heard of such an event and suggested it may have been moisture blown in from the rain. Nothing under the body work was wet though and while I am charging the battery to do some testing I was curious if there had been anyone else with this weirdness. Anyone with a similar experience that may have some insight, I'd like the input. Pretty strange.
Headlight/light the trunk light switch
Whatever it's called. I never use it . The switch on the front of the right hand control, that will turn the headlights on when the bike is off. It can light up the trunk interior when the lid is open. Possible malfunction in that switch? Maybe got wet ? Bike cover pressing on switch? Something to check.:dontknow:
