Thanks for sharing with us. Stay healthy!!
Printable View
As I recall Mike said the M-C struts were put together from individual parts and pieces, not a complete off the shelf unit. Which way did you come up empty, one or both?
I found the ones from Amazon by Lift Depot noted above worked quite well other than I had to make a spacer for the eye end to accommodate the smaller diameter Spyder bolt. It's a loose fit but for the trunk lid that doesn't matter. Here's what I did. https://www.spyderlovers.com/forums/...=1#post1406313
For sure, for a direct "plug and play" replacement the BRP ones are the only ones available, it looks like.
Excited, I too gave a look at possibly using aftermarket items based on posts here. One post seemed promising, but required buying a series of individual items. Uncertain if the results would be acceptable, I toyed with simply buying oem parts.
Having worked with Gas Springs in other applications before, I knew most likely the issue was pressure loss and not complete seal failure. Opted away from buying any parts, and still never sorted out if the items listed in these Spyderlovers posts would be the equivalent or better than oem.
I bought a prop rod from Pierre at CanamSpyderaccessories.com. It was easier than replacing the gas shock. It looks good. works good. Have not been ryding yet so use has been limited to install but seems ok.
Just replaced my trunk strut with the Amazon part referenced above. No more falling trunk lid for us.
Here's the quick, easy, and inexpensive solution to a bad trunk gaz shock: Don't replace it! Just get one of the flat, blue, often free LED flashlights from Harbor Freight. It's the perfect size and shape to slip between the trunk hinge and the housing to hold the lid open. It's a good idea to have a flashlight on a vehicle anyhow, so keep it in the trunk and it'll be there for either purpose.
Just received and installed new gas shock for trunk lid. Works great. Ordered from Amazon. Offered by Lift Supports Depot, $44.00. Bruce
