Originally Posted by
Deanna777
If you get the D.E.S.S again, take a picture, ( show the picture to your dealership) the D.E.S.S. Module is UNDER WARRANTY, and have your dealership open up a case with BRP, and be sure that your dealership has the D.E.S.S module, ( so you are not spyderless) and also, have your dealership replace the Ignition Switch which is UNDER WARRANTY also, have your dealership reprogram keys, and get a new trailer lock from your dealership.
The part # for the 2014 RSS is: 710004190.
I got the following info. ("Solution: Replace the D.E.S.S. module. Program the keys using B.U.D.S. NOTE: If after the replacement of the D.E.S.S. Module the problem reoccurs, update the previously opened BOSS Web Case and report this situation) from my dealership.
Also, try "Turn on/off immediately and DO NOT LET YOUR SYSTEM SHUT DOWN for 4 to 5 cycles. Also, I got this from an email from a BRP TECH " We have had cases where a cell phone or magnetic card, placed near the ignition switch cause this. This includes any device that may emit some type of frequency".
Where do you carry your spare key?
Keep us posted!
Please post on this thread, so new/and current spyder owners now.
I will check this thread, when I get a chance, ( I am still in the work force). I hope the above info helps.
Deanna
