I put mine there also, plenty of room and easy wire fishing.
Printable View
I had installed an AutoSwitch Motorcycle Garage Door Remote Activator AS-7G (got it on ebay). Installed on our 2014 RT Limited when it was relatively new -- installed in July 2014. It has worked well and wires into the bike. I wired this to my fog lamp switch (as the trigger toggle) and when I reach near the garage door, I just toggle the fog light switch and it allows the transmitter to open the door. Works well, but limited range. You need to get close to the garage door. Also, it took some time to wire it in. I like that it is invisible on the bike (tucked under the tupperware) and uses an existing toggle switch to trigger the garage door opening..... It was around $30. I don't know if I would spend that much time on putting one in again....On our Goldwing, I just used double stick tape and put a small garage transmitter in my side case...much easier and lower costs!!
If you navigate to home on my GPS you end up at the local Police Barracks.
Mine is velcro'ed to the underside of my glovebox, no one ones it's there except for me and, well, all of you now, damn!!!
+1 for keychain remote and velcro
thanks for that info
For the garage remote, I mounted with two sides tape since only need access every couple of years (or more, have never replaced a battery in one). If I recall, I stuck it to the outside (bottom side) edge of the glovebox.
For the fuse block, I found that there is an area under the edge of the windshield that my fuse back slid into. I slid it in, then used 1 zip tie to secure it. Not a beautiful install, but does not move and very easy to remove if I need to add a circuit.
Sorry I do not have pictures.
OK, if this is the wireless one that has the 10 year non replaceable battery I can chime in with my experiences with my 2018 RT Limited.
1. it will not fit in the center spot, that has a round hole not rectangular
2. it will be slightly too deep and bottoms out.
3. it will snap into the rectangular cut-out (with depth modification)
Now let me start off by saying, mine was given to me, so I had zero money invested or lost if I ruined it.
What I did initially, was just add a ring of foam sticky weatherstripping to the opening and leave it sticking up and not snapped down. But I didn't like the cobbled together look and knew it was "this close" to fitting, so I decided to take my chances and modify it. I won't know until later down the road if this works or shorts out in the rain, but I removed the plastic housing around the bottom and added a single layer of duct tape just to keep everything tucked together. I was trying to just shave off the bottom plastic so it would fit for depth, but the sides broke off too, so I made the best of it. [ATTACH=CONFIG]174503
I think if you are handy and get the wired version and add it to your cluster it will fit better since the battery pack of the wireless adds quite a bit of depth.
So, at the moment mine is in, snapped down and works perfectly and looks nice. BUT, not sure long term if I breached the water proofing by cutting off the plastic.
I Velcroed an opener to the inside rear wall of the glove box; has worked fine ever since I bought the Spyder.
I have a mini opener for our garage door. I keep it in my rider jacket pocket and just press as I'm coming into the driveway.
