Here's a video explaining why the Transmission "CLUNK" occurs!
While visiting my Can Am Dealer parts counter I was told that the #1 question ask of the mechanics is "Why does my Spyder go CLUNK when I put it in gear?"
Anyone who owns a Spyder may be asking themselves the same question:
I was going to do a video with a part from a Spyder Tranny but the deal says they can't find the part I was going to use for the video so here is the next best option. If you did not know this, the Spyder transmission is a sequential shift type transmission much like a F1 formula racing car, in fact they look very similar inside.
There is a video out there from Driver61, who is a formula race driver, and he does a great job with the insides of the gearbox.
Once you look at this video you'll have a better idea of how your Spyder transmission is built and I'll explain why it goes CLUNK when you go from neutral to reverse or neutral to 1st gear!
https://youtu.be/XQOhuN-HHfY
So here is why it goes CLUNK!
Anytime the motor is running, with the transmission in neutral, and the clutch is disengaged such as it is anytime you are starting out first thing each trip, here is what is going on.
Even though the clutch is "open" meaning the friction plates and the clutch disc are not held tight together, the oil in the wet clutch system still allows some friction between the two clutch members and so with the tranny in neutral the "Lay shaft" will rotate! The "Lay shaft" is the engine input shaft and the output shaft is the one with the belt drive gear on it. So basically the input shaft can freewheel!
So when you put it in 1st or reverse, this input shaft, the "lay shaft" has to come to a quick stop because the engagement dogs on the gear you just engaged has now "grabbed" ahold of the required gear and so the spinning input shaft and the associated clutch disk now come to an abrupt stop and so you get this very solid "CLUNK" and all of that is NORMAL.
The same thing happens if you go from neutral to reverse but if you have noticed, it does not happen when you come out of reverse to 1st if you don't pause in neutral. That is because you have the input shaft stopped and therefore no need to "arrest" its free spinning movement again.
This shift clunk is normal for this type of tranny design and also the reason for the rear sprocket (Pulley) to be mounted in rubber shock mounts. It helps cushion the sock of bringing the input shaft to an abrupt halt!
I think if you'll take the time to watch the F1 transmission video you'll have a whole new appreciation for the Spyder transmission design.
Granted the shift dogs in the Spyder tranny are a different design from that of the F1 tranny but both will handle the input power they need to handle and give years of service.
So stop worrying over the "CLUNK", it is just part of how this design works!
I hope this helps,
Dave C.
