I have tried to download/upload/insert a signature and signature photo. I can not get it to show up on the posts. Any help would be apprecaited.
Thanks in advance!!
Printable View
Thanks in advance!!
Go to settings...go to edit signature...I'm sure you have done this already. Now put the signature information in and if you are adding a photo go to the picture box on second tool bar and select picture from file. Should take you to the pictures on your device. Select the picture and then click on upload. May have done all of that too..now you should have what you want to appear...save signature and it should work for you...at any rate thats how I did it...good luck..:thumbup:
Are you sure you are putting it in the right window?
When you are on the edit signature page, the first window is the preview window.
Scroll down to the next window and place it there.
I have done all the above and all that shows up in the upper window is a notatation saying "sigpic" but no photo, even though I have "inserted" the photo from the lowere box. I have tried to resize it thinking that may be the issue but that has not helped either. :banghead:
Don't know what changed but now it is there. Thanks every one. :yes:
I have the same dilemma. After trying all of the above advice, nothing has changed. Maybe posting this new reply will make it happen. not holding my breath though.
The signature change requires a post after chaning/adding to it, as its cached for performance.
