For a 2020RTL which mirror vibration fix is the best the one from lamonster or the one from the factory or are they the same. Thanks
Printable View
I have the Lamonster version. It's quick and easy to install, it's cheap and best of all, it just plain works. Some have said the dealer will add the "factory" fix for free, others have said they had to pay for it. Either way, you have to make an appointment and wait while they do the work. I spent my 25 bucks, enjoyed the time getting to know my bike in the 15 minutes it took to install and did it when I wanted.
I was thinking about Lamonster's fix on my last ride, because I don't notice the mirrors anymore. The mirrors are perfect now, but a little harder to get off in the unlikely event you'll need to remove them. Took me probably 45 mins to an hour. One stabilizing plastic pin had to be cut, to avoid flexing the mount base. No big deal, just a snip with side cutters. Seems like a great fix to me.
Apparently BRP doesn't test ride their Spyders before releasing them. Everyone I've talked to had the problem. My 2021 had the shakes and I also had to use the Lamonster fix. The fix works as advertised......no more shakes. To me, this appears to be a safety issue and BRP should do a recall fix for all 2020 & 2021 Spyders.
there is a service bulletin released last year addressing this issue and mine was performed by dealer at no cost. Has corrected the problem.
My 2021 RTL does not have the issue.
Going to have my dealer look up this service bulletin when I take my RT in for a front pulley replacement. Sure would beat me paying extra for an after market fix. Does anyone know what kind of fix the dealer does? Good to hear that it fixed your problem Baxter. Did a 270 mile ride the other day on an existing 250 miles and the left mirror began to vibrate. Not sure if it was the mirror itself or the entire mirror enclosure.
You can pop the cover off the mirror and tighten up the nut that holds the mirror spring. Don't tighten it too much. A 1/2-3/4 turn would be sufficient. I did that aswell as adding Lamonsters fix. The "official" fix is basically the same as Lamonsters fix but uses fancier parts. No matter which version you use/get, if you ever need to remove the mirror (which is unlikely on a 2020+ unlike the previous gen where you had to remove them for EVERYTHING), you'll have to unbolt them.
I did notice my left mirror housing had more play in it than the right side so think the entire housing was vibrating. Will see what the dealer does next week. Otherwise will take up your suggestion.
The whole mirror housing shakes because the housing is held on with spring-wire clips that slip over tapered bolts. If springs are not tight there's small movement on the bolt. The fix is to remove the taper bolts and replace with T-bolts and nuts.
I did the $22 Lamonster fix to the wifes 2020 RTL. Left shook like crazy but the right was halfway ok. Now no problem and do not have to leave it at the dealer.
I also used the Lamonster fix, in the long run it was cheaper for me as I would have had to go 40 miles to the dealer, wait on them to get around to it and then ride 40 miles back home.
I spent the evening putting on the lamonster mirror shake fix. For the life of me I can't get the outside plastic to snap back on..... Any helpful hints?
Has anyone tried the canamaccessories.com part called the Ultimate Mirror Stabilizer? $39.95 plus shipping. Just two plastic parts which snap in. Looks easy. How well do they work? Anyone know?
I went with ‘wedgies’ on my F3L. Work great and a 2 minute install
Where can I get the wedgies? I'd like to rush order them for a trip I am heading out for this weekend. It'd be nice if possible. I messaged Squared Away, but I'm in crunch mode. It's not the end of the world if I do not get them, but it's worth trying. Thanks!
I had problems with my left mirror on my 2021 RT so I bought the ones from slingmods. They are more than the lamonster garage ones.
Oct. 18, 2021
How did they fix the problem ? My problem is the two piece housing is not tight together so it rattles.
1+ for the Lamonster's kit, his instructional video is highly recommended as well.
This is the only vehicle I have ever owned where the mirrors vibrate so bad that the image is fuzzy thereby making the bike somewhat unsafe
Please post the recall here so I can take to my dealer
