ST Cruise Control Difficult to Set
This is a new problem. The bike has performed flawlessly for the previous 16K miles.
2013 STS. SM5.
In the past few rydes the cruise control has been acting strange (erratic).
It will turn "on" with the right hand grip slide switch.
When I push the slider down to set the speed, the indicator in the instrument cluster,
briefly flashes green "Set" and immediately reverts back to showing "On" in black and white.
The cruise doesn't turn off it just refuses to set. After a few miles of fiddling, turning off/on and
reengaging the system SOMETIMES works.
I lift the brake pedal with my toe and push outward on the clutch lever with my gloved hand. (ATGATT)
I'm thinking a finicky sensor.
Now my question...How many and where are the cruise control sensors located.
I know the brake switch can act up and affects the cruise setting.
Possibly a sensor in the clutch system??
Are there any other switches and sensors that I should look at??
