Is it possible to tow my spyder?
Printable View
Seems like it is possible but I would not try it, you can tow any vehicle but who knows what damage it could bring, why do you want to tow it.:banghead:
I was thinking the same thing using a car dolly, a while back but was told not to do it as it would damage the bike. Not sure why.
I think that on a dolly, you have to put the drive wheel on the dolly and the non-drive wheels on the ground. So the Spyder would have to be towed backwards. It's front end would scrape on the pavement in that configuration. All the dollies I've ever seen are configured for 2 wheels, not one. There's also the inconvenience of having to remove the windshield to tow it backwards.
If you want to tow it, you should put it on a trailer facing forward.
.... It should face forward... on a wheel dolly, and the belt MUST be off......... It's a real hassle............. but doable....... Mike :thumbup:
Only with all three wheels on trailer. Flat bed tow truck. Something to do with the fluids & transmission neutral position quirks. Best to not try more than few hundred feet if at all possible.
Towing it would probably be like water skiing on it, yes you can do it ................................ but probably only one time :roflblack::roflblack::roflblack::roflblack:
Better answer ........................ NO
Cruzr Joe
I'm with them :agree: outside of the emergecy tow to get you outta the way....don't. There are nice trailers even folding ones but then thats not what your asking...:thumbup:
I was thinking about modifying something like this to attach to the front A frames?
http://www.spyderlovers.com/forums/a...d=124461&stc=1
I agree with Mike regarding the belt removal, a PITA but doable. OTOH, just because one can doesn't mean one should. I personally wouldn't want mine moved any way other than on a trailer or a rollback.
Even if dragging the drive wheel wasn't a REALLY bad idea, I doubt you'd be able to fit that tow rig under the Spyder without it dragging.
A simple flat bed trailer is pretty easy to work out. Mine is a simple jetski trailer with nothing more than some decking installed to make a flat surface.
Sent from my Nexus 6 using Tapatalk
I spent a good while last summer trying one-way options with U-Haul. Too wide for any of the 4 wheel trailers with ramps because the opening is narrower than the trailer bed. I still think the two dolly with the Spyder belt removed would be a good idea. However U-Haul will only rent for recognized vehicles. You could lie about what you are towing, but in case of a wreck would be in a bad way.
Saw this setup behind a motorhome today. Slick idea (I thought)
Oof! Wonder what the tongue weight is on that setup?!! Looks like it's bending already!
I always flatbed.
Be safe get a small tip trailer such as Harbor Freight or Costco if they still have them. ;)
Has anyone towed their spyder by the rear wheel using motorcycle-rack rear wheel towing system model # CARWT500.
If you are wondering why I want to tow my spyder I live alone and it would be nice to take my spyder in for service using my SUV or use my spyder to pick up my USV and then tow the spyder home. Thought about using a trailer to haul the spyder but not sure the spyder could tow the trailer home when leaving the SUV at the survise shop.
Not sure his would work on the rear tire of a spyder I'm single an dont have room for a trailer at my house and my dealer is 60 miles away would save from renting a trailer if the F3 had to spend more than a few hours at the dealer. Anybody have any experiance with these?
http://www.magnetatrailers.com/recei...towcaddys.html
