I have a 2013 st , I ride mostly 2up. Does anyone know if the occasional 2up shock for the f3 would fit on a st or do I need to go the 600 dollar elka rout?
Printable View
Take a look at this thread for changing the rear spring to higher rate.
This may be my 2019 winter project.
https://www.spyderlovers.com/forums/...change-out#top
hi i was wandering if anyone has found a spring replacement for the rear shock for riding 2 up. the factory shock has no adjustment and does bottom out ocasionally when riding 2 up. i saw the thread on replacing the upper spring on the 2spring set up but haven't found any options available for the single spring model.
Get a hold of the member spacetiger https://www.spyderlovers.com/forums/...953-spacetiger from the link in the second post above. He helped me with front springs for my ST Limited. The ride and handling is so much better now.
