Anybody know or can suggest a radio and speakers that can be installed in my 2011 RS?
Printable View
I bought one of the SHARK units ( lots of choices ) on E-bay ..... ( even LaMonster did ) Don't go crazy, stick with TWO speaker models 650 to 1000 watts is more than enough ( you are limited in speaker size ), and make sure you get a WIRED remote for it..... I you love FM get something else .... I only used mine with an MP-3 device and was quite happy .... try to mount the speakers as high as possible ....WHY ? - because that's wher your ears are :roflblack: .... remember you are on a Mtc. = ambient outside noise , engine , wind , the tires on the ground plus all the reat out there .... to try an achieve the best possible sound from such small speakers I swapped mine for 3.5 in JBL 2 ohm models .... this was a hugh improvement, but listen to the stock ones first .... the small receiver fit into the area on the right side of above the FRUNK .... the remote mounted on the handle bar good luck ...... Mike :thumbup:
Can u send pics of your setup?
Do you need speakers from the boat? Otherwise, the water will flood them.
How are you coming along with your speaker project? Did you find a solution?
