Dang, last week they were a must have item. ;-)
:hun:
Printable View
:hun:
Just back off on the belt tension a little from sec, turn up the radio and ride the darn thing!!!:thumbup: Or put it on , and check the wheel every now and then when you check your oil, or tire pressure! Then if it starts to go you will know it before it becomes a problem!!!! My RT has a small vibration, but you know I tell myself I could be riding a HD trike and it could be a LOT worse!!!:roflblack: Ride more worry less!!!
Well with all this talk about the belt harmonic vibration dampeners failing-------- I had to go and check mine. It's in perfect shape, Roadster Renovations BTW. Rolls smoothly with NO play and original tension on the belt. It's a mod I'm glad I've done but---- also glad I checked. Now I'll check at least once a year. While down there I checked the rear tire pressure------ it had slipped to 16.5 psi with this temp drop ( 15*F outside) last night. A 30* change in a month ( average night temps) and it will cause a drop in tire pressure. It's back to 20 Psi now ( A General Alitmax).
Lew L
I discovered I had the BRP Belt Tensioner inadvertently on my girlfriends and my 2018 F3-T after installing the wiring for our heated gear connection under the passenger seat. Our Spyders were purchased from different dealers and we didn’t ask them to install the Tensioner, so apparently it came installed from the factory.
I immediately ordered two roller upgrades from Lamont. The quality of the roller he sells verses BRP is like night and day. The BRP roller feels like plastic with one little bearing and this one is rubber with double bearings.
The larger roller is from Lamont.
There sure is quite a difference in the inside diameter measurement of the bearing of both rollers you pictured. How is that going to work out?
Lamont includes a bushing with the roller, you can see more pictures and a video on his store site, http://www.lamonstergarage.com/can-a...ley-lamonster/
Big shout-out to AY4B for bringing this to our attention. Checked my RR tensioner and found roller detached from one bearing and coming apart on one side. Would soon have caused belt damage for sure. Removed it yesterday and will throw it away - not worth the worry of a roller on my belt. 18 months old and about 12,000 miles. Money wasted. Everyone should check these carefully and often. Thanks again to AY4B.
To be fair, all experiences ”should” be shared, in order to choose who’s Dampener to install and use, if any. As I recently posted on this thread, after seeing the photo of the damaged Belt, by a failed RR Roller, I removed my RR Dampener from my RT Limited. As I posted, the Roller still rolled, but not with out binding, and the Spring felt much weaker, i.e. much less tension than when I first installed it after the first one broke. But what I failed to share was how many miles the RR Dampener had been installed on my RTL. I first installed it at 1500 miles, and the spring lasted about 1000 miles before breaking. I installed the new replacement Spring at around 2500 miles, and just removed the entire Dampener at around 38,000 miles. So, the RR Dampener “ should” last 25,000 miles, but I would not vouch for its usefulness , if any, after the first 5000 or so, after installation. As I said, I never ever got rid of my Belt Chatter, with, or with out the Dampener. But another thing I want to report is, since removing the Dampener, the high pitched Whine I always heard from the front left Sprocket area has almost disappeared, so I now believe that Whine always was created by the spinning of the small Roller Bearing of the Dampener, and not from the Sprocket Splines. Caveat Emptor!
007James
I have never understood the need to apply pressure to the idler pulley. I set mine to barely clear the belt when not on bike.
I have close to 20 thousand miles on my BRP idler and have no complaints - so far.
I have modified some parts but still use the single bearing roller.
To me it is amazing how something can be "better than sliced bread' today and when someone reports a problem with one , people come
out of the woodwork with negative responses.
We all have problems with our bikes - some worse than others.
Please don't stop reporting problems - everyone benefits by learning from them.
My 2 cents worth,
Tip
I have the updated brp damper (stronger spring) with lamonsters roller. 11k miles on my 18 F3L. Still going strong. All I know is without it my belt vibs bad around low 70 mph. With it only a very little vibe on decel only for a second over 70 mph. My belt is at lowest tension spec. I keep an eye on it regularly. So will continue to use it. If the roller gets loose I will buy another. Nothing last forever.
I’m getting a strong vibration at 77 mph (2019 F3L) which isn’t a huge issue under normal riding conditions. However, there are on rare occasions when I want to reach this speed on the highway.
Pretty sure it is a belt vibration and the dealer seems to agree but I’m going to take it in for them to take a quick look anyway. The bike is still under warranty so I guess now is the time. If it is in fact determined to need a belt dampener is it reasonable to expect this to be covered under the warranty? For some reason I suspect not.
Even if a belt dampener is needed I may hold off for awhile given some of the issues mentioned on this site concerning the belt dampeners.
Look at purchasing one of these and I doubt you'll have any problems...
https://www.smoothspyder.com/belt-tensioners/
Follow-up. I did meet with my mechanic and he did take the bike for a test drive. He agreed that the vibration was from the belt and that a belt tensioner would be of some help.
Knowing that the belt is likely the issue and not any other major cause I think I can live with this for now. So far I have only needed the 77-80 mph speed on the interstate passing in the fast lane. This does not happen very often. I may rethink this issue if I plan an extended trip requiring a lot of interstate travel.
Poasttown
If you find that you have to go to the dark side and put one on, just make it a habit to check the bearings in the wheel when you check your oil, or make it one of your check points before a ride! If you give it a spin and it feels dry, well then you know there troubles ahead, and do some thing about it before you smoke a belt!! Myself, I like to keep it simple know and live with some things!!
