$715 for the Spyder version.
Printable View
suggestions: # 1 Pull the front wheels up on 2x6 boards cut on a 45% angle on the end.
# 2 Use your service jack to lift up the front with a block of wood protecting the frame.
# 3 make two small wooden boxes out of 2x6 boards to support the weight of the wheels and suspension while the shocks are off.
It works for me. Hope this helps.
I added air to my rear air suspension using the schrader valve under the seat and the Lamonster approved digital cordless air pump set to 50lbs.
Hi there,
Is it easy to use this lift? What model do you have?
Thanks for your response in advance.
:spyder2::spyder2::spyder2:
Which Lift are you referring to? The OP's, the HF, or the Big Blue?
I have the Harbor Freight version, http://www.spyderlovers.com/forums/a...8&d=1518536292
used it many times for Oil Changes, Sway bar install, wheel and tire changes, frunk removal, and it's worked well. I do have jack stands under the front wheels and rear swing arm. Sometimes have a car ramp with blocks under the rear tire when I get it up really high.
http://www.spyderlovers.com/forums/a...9&d=1518536304
Here's how I got the extra height to install my BajaRon Bar
http://www.spyderlovers.com/forums/a...1&d=1518536329
Even without the Jackstands and Tire Ramp in at this point, the Spyder was very stable on the jack, though I wouldn't work on it
without at least three other fixed supports like the jack stands and ramp.
Here is my post from another thread on the subject. See post # 3.
http://www.spyderlovers.com/forums/s...95#post1333695
George, just wondering are the rails on your Powerbuilt jack short enough to not support the Spyder RT's central and side angled tubes when lifting. or Why did you feel you needed to add the extra adapter to the lift when lifting the Spyder? The HF jack I got has 14 inch rails that easily support the Spyder RTL. Just wondering.
EDIT, Sorry I was looking at Post 4, now I relooked at post #3 and see how that helped with your normal type floor jack versus having to purchase a Motorcycle lift.
Everyone
I have a pair of car ramps will be using to get the front end up. I am just wondering if I could use the hitch to lift the rear end until i can put some jack stands , would i be able to support the rear of the bike using my jack stands on each side of the hitch. I hope I am not be too confusing for everyone here. Does the bike have to be level or as near to as possible to do the oil change etc. Thanks guys
Dave
I use a Hi-Lift jack to raise the back end of my Spyder lifting by the hitch but then set the rear wheel down on blocks with at least some of the weight of the Spyder on it. If I'm changing the rear tire or aligning the belt then I use an ATV jack (like the ones others have shown and used) to lift it up with the front wheels on ramps or blocks. I usually set the ramps behind the front wheels and back the Spyder up on them so the length of the ramp doesn't interfere with things like changing oil. One problem with ramps is they tend to slide when you drive the Spyder up on them so you have to hold them in place some way.
For quick and easy lifting, I have this harbor freight aluminum jack. A little small for most auto/truck work, but great for the Spyder. It got the back wheel off the ground, no problem.
2x6's under front tires works.
I just realized that the interlocking plastic blocks and ramp I use to level my travel trailer at the campsite would be ideal for this application also.
I have rolled her up on 2x6s or added air to the suspension (up tp 70 lbs) and that works to get the jack under. I have an old craftsman red jack. I tried me the hf one since it lifts higher but it wasn.t as stable
I just installed Baja Ron's Shock Adjusters on my RTS. Couldn't get to top nut on shock so I took the frunk off. I have a motorcycle lift and raised it from the front end, put cement blocks with 2 x 6 boards on top of blocks under the tires. Jack stands under the A-arms. Be sure to rent the spring compressors when you order the BJSAs. I'm also installing skid plates under the frunk while it's off, Cleaned the radiator fins and cleaned up some of the wiring. All this has taken me about two weeks cuz I can only work out in this 90-100° heat for a few hours at a time. I should have it bank together and on the ground tomorrow. I'll be great to be out buzzing around town again. I really miss riding my "Mistress".
