Does anyone know how to get to the battery compartment in a 2014 RS
Printable View
Thanks. but is it in the same place as a 2014
Your avatar shows an RT. Now looking at the RS parts layout the battery is now located in the front on the unit. Must be like the ST in the frunk under a panel. Owners manual should show You how to get there. Good thing to read if you have it if not worth getting...:thumbup:
The battery in all models 2013 and later is located behind the front trunk. To get access to it on a RS, remove the battery access panel located inside the front trunk on the rear wall.
Thank you all for your input. As for my avatar picture. Yes, it is RT, but my wife has RS, there is a difference. If I had time to sit around all day and read my manual I would do it. Since I've had other things more important to do other than read the manual at this time, I figure I would ask someone to save time.
