i had same exact as I mentioned here in old post.
Did Corbin fixed it?
Printable View
I ordered my corbin bags through our local dealership and we still have not heard if the two bags are being replaced under warranty. I can't believe it if I get stuck with any bill over this! In repsonse to your question about locking, both of mine locked after you pushed down twice on them so the latch actually fell into the correct hole on the other end! It appears that the latches were too small for the lid and were not lined up appropriately to latch properly when you lowered the lid. Once you pushed again on it, the lid would latch, but because they were not aligned correctly, I had a bunch of stratches on my chrome plate and the rest of the lid didn't seal all the way and leaked when riding in the rain!!
Glad to hear the prior posting received his new bags and they work! Any suggestions on next steps as it is very difficult to get a timely response from this company? Myself and the dealership have provided everything that has been asked of us.
mine even when locked, with speed they opened. And that is when I called Corbin direct and gave threat to take it further for my safety. Also, when you lock it, put your finger between body and lid, it will open.
I still can't believe that Corbin after all these complains, are ignoring them and keep sending the bad ones. It is not cheap bags...
I'm going to post new one, big cry/shout to Corbin. It may stop new F3 owners from facing same issues.
You all might want to take a look at this post.
http://www.spyderlovers.com/forums/s...Fair-treatment
Hope they do you better than this member http://www.spyderlovers.com/forums/s...orbin-2000-for
Just follow the instructions. Really quite easy. ( I was able to do it! :)) You will have to replace the passenger hand rail bolts with the Corbin studs. Do them one at a time and you shouldn't have any problem and won't have to disassemble anything. Good luck! :thumbup:
Nope, I didn't
Talked to the Daytona store for the 5th time on Feb. 4th where I ordered them.
They said they would call me the next day with some info.
Haven't heard a thing and not holding my breath.
It will be 4 months in another week, getting ready to call my CC company.
The bags have a stiff panel facing the wheel that helps keep its shape. As well though, I remove the handles and made small plates of pvc type material with holes drilled that allow them to mount to where the handles are. But the straps are designed to keep them from moving at all.
http://www.spyderlovers.com/forums/a...d=125155&stc=1http://www.spyderlovers.com/forums/a...d=125156&stc=1
