Originally Posted by
stewartj239
I got the rear Elka shock installed this weekend. I can honestly say that I had no perceived issues with the stock shock. All of my complaints were with the front shocks, but since I was replacing the fronts with the Elkas, I figured it would offset the balance of the Spyder if I didn't replace the rear shock as well. This is the 1+R shock and compared to the stock shock, you can clearly see the difference in quality. It looks much more solid in design as well. The 2nd picture was taken from the right side of the bike. I have the purge valve facing the front of the bike and the rebound adjuster facing out the right side at the bottom. I got a good tip from a friend on the forum who said that there are reports of the lower shock bolts bending, so he hooked me up with a hardened steel replacement bolt instead.
