Old school :doorag:
Printable View
This is a familiar scenario for me, 2014 RTS. Dealer tech, who is quite good, went through the usual fuel cap, sensors, purge valve, etc. Reset code p0172 several times only to have the code reappear with check engine light after a few hundred miles. In the end the factory BRP sent fixtures to check and adjust cam timing which was found to be out of spec. Been 2000 miles since and problem has never reappeared. Finally fixed. Of course I was out of my Spyder for 8-10 weeks by the time it was finally fixed. One nagging concern is why the problem appeared after 4500 miles - thus could the timing change again at some point?? My recommendation is to have them check with BRP about cam timing.
I have been a machinist for forty years have ran just about every machine you could imagine, had to live +/- .001 my whole life so even if they fix it it will never be the same,
in my world it would have a NFG tag on it.
Ran my own machine shop for twenty years ( I Like MAZAK ) if there were any problems at all my customers were up my arse til I took care of the problem, Big corporations
like BRP can hide behind their size and tell folks like me to go pound sand, in the perfect world I want what I paid for just like their ads say or my money back.
If only Honda made spyders.
I know your frustration. I went through it for over 2 years. December 2015 to April 2018. So long, that my BEST warranty ran out. So much for that purchase. If you're not willing to slog it out, and perhaps spend a lot of cash, plus deal with the frustration and incompetency of both BRP(they failed to identify what had been long known to cause the problem) and a clueless tech. It may be best to end it now?
See post 9. BRP obviously has a short memory.
https://www.spyderlovers.com/forums/...ght=cam+timing
If you reported the defect during the warranty period and they didn't fix it properly, you're still under warranty until it IS fixed properly. The FTC says, "if you reported a defect to the company during the warranty period and the product wasn't fixed properly, the company must correct the problem, even if your warranty expires before the product is fixed." https://www.consumer.ftc.gov/articles/0252-warranties
Depending on your situation, you may still be entitled to fight with BRP but it would depend on when you last reported the recurrence of the problem to them and what they said. Let's say you brought the Spyder in to be "fixed" and you left thinking it was fixed, but a week later the same problem occurred. You bring the Spyder back in and they say, "Sorry, your warranty expired yesterday." That's legally wrong, and even if you paid for the repair then, you should be entitled to get your money back now. OTOH, if your Spyder was working right in April 2018 and you never reported the recurrence of the problem to them until MUCH later, it would be very difficult to prove their last repair wasn't done properly since things DO break on their own sometimes.
Trust me on this. I left no stone unturned. I had documentation out the kazoo, for every dealer visit and everything they documented and verbalized to me. In the end, the dealer and BRP didn't give one rats azz. Just the facts.
To this day, I have all the events well documented.
Sometimes things go bad....this was one of those times.
Regrettably, it ended a 50 year relationship with my dealer and brought me to 1 and done with Spyder ownership.
The Spyder is a great machine but, if you get one that happens to be......uh, troubled. At some point the only one who cares.........is you.
Just got my 2018 F3 LTD back from the dealer for the second time for the po172 code.The dealer inform me that BRP is coming out with a TSB reflash for the problem the parameters in the Ecu need to be changed.Sometime mid September to late September he said I should be getting a letter, mean while they said to run 87 octane gas. But no problem to drive it .
