GO for it. IMHO you will enjoy it alot.:clap:
Printable View
This is does not effect every SE but it is a fix for some of them for sure.
If for whatever reason your SE gets stuck in gear and you pull over and turn the key off an then turn it back on again and your parking brake beeper does not beep at you like it would normally then your tcm has shut down. What seems to be happening is there a rf feed back coming from the coil pack that's messing up the computer. The fix is to run a ground wire from the coil pack mount to a good ground on the frame. I called one of my BRP contacts to verify this.
