LED signal lights installed
The LED signal lights discussed in this thread have been recieved and installed. These lights are exceptionally BRIGHT. Really----- don't look directly at them for more than a sec. or two. You will get hyper flash and I had to try a few times to fix it. When Lamont says "HOLD DOWN" the flasher button he means it. But the 14's and newer 1330 :spyder2: will fix hyper flash
Again these lights will wake up the distracted fools who drive among us. It is a farkel worth considering and you don't have to remove the mirrors;).
Hyper flash causes::::::::
Kaos
Front signal light up grade.
Quote:
Originally Posted by
BLUEKNIGHT911
..I agree with everything you've said about being seen......but I'm not sure of what else you can do about the FRONT turn signals to improve them.......Maybe turn the TIP lights on the fenders to work as TURN signals....Someone here ( a vendor ) must make something that will combine the functions......:dontknow:......Mike :bbq:
I know that many motorycyles ( my V-Max included) has front marker lights that are also the front signal lights----so it's doable.
Kaos
