Do you install these in the fog light opening on the ST?
:dontknow:
Printable View
I have a 2011 RT LTD and hubby has a 2012. We just made a 9611 mile trip from Oregon to PA, Canada, etc. and the heat at times was unbearable. My right leg actually got burned on the inside from the engine heat. There has to be a fix somewhere. I was wondering if just putting more 'heat wrap sheeting' on the inside of the "Tupperware" would do any thing, but I am just a rider, not an engineer.
:shocked: What are you wearing for riding gear? :shocked:
Here's a fan that might do the trick... It is a 12v 3" fan normally used to ventilate the bilge area on a boat and built for rough use.
It pushes air at about 145cfm and draws less than 3 amps. You can buy these at many places less than $20 including Amazon, eBay, West Marine, etc.
I am currently experimenting with one of these on my RT, using a manual switch.
Perhaps they ride naked?
I agree if airflow isn't removing the heat, I don't see a fan doing much...unless there is just a dead spot that the heat is building in?
Wrapping the exhaust properly on a vehicle can do wonders. I even did it on my minibike. LOL
Just time consuming and takes patience.
I think that if it's small enough; you could just about find it a home anwhere you could fabricate a mounting bracket, and plumb some air to it. :thumbup:
Please let us know how this turns out. Maybe I'm thick headed, but I think this may be part of the solution...
if or when BRP comes up with a permanent solution.
The 2014's may clue us all in on airflow changes through the Tupperware.:popcorn::popcorn::popcorn:
Does your RT have the fog lights or not? Do you use that opening to get under the Tupperware? Where will the entry and exit point be?
Lots of room to mount it when the stock airbox is gone.... It sits just behind the rh Foglight and pulls cooler air from inside the fender to displace hot air around the top of the engine.
Below is a pic of the fan installed on my RT. Understand, I did this solely to relieve the level of heat around the KewlMetal Intake since my oem Airbox was replaced... It may or may not affect any heat levels for the rider. I am using a manual switch which I only turn on when I get trapped in traffic or need to sit idling for a while.
And, yes, it is making a real improvement as measured by a VDO Temp gauge on my dash. This blower fan really pushes some air in a small space...
If anyone wants more details send me a PM.
This sounds like some really good news!. From other posts I know people have wanted to do this and see what the results are. Keep us posted as you get more time on this mod. Can you record some before and after temp readings? Maybe this will be a catalyst for other people to try it. Hello BRP? Does the hot air exit out the bottom?
No, the blower is picking up cooler air inside the fender, near the RT scoop, and pushing it upward across the engine.... the heat has to be mostly flowing out the top vents in the tupperwear.
My heat level around the seat/glovebox area dropped significantly when I originally did the KewlMetal Intake conversion. I have not noticed much change while riding using the blower but may get a better test this weekend going to Birmingham.
I guess that you could just look upon the exercise as a way to get your bike back on the road and more enjoyable... :thumbup:
I am waiting for the arrival of the Attwood 3000 fan. It pumps 90 CFM through a 3" duct and I plan to position it wherever I an find room, with a duct running down under the Spyder. Ideally, it will create a vacuum under the tupperware, and suck fresh air from all the places heat is now coming out, under the seat, as well as any other small openings, and vent it out the bottom. I plan to install a switch so I can turn it on when stopped or stuck in stop and go traffic, and turn it off while moving. Hopefully, this should make the ryde more comfortable . . . although, yesterday, on a chilly day, that warm seat actually felt good!
My thought is that the best path would be to take strong measures to block the flow from around the seat and glove box, the push the air upwards to exhaust through the vents in the upper body panel. Those vents are not very effective because the deflectors block the air from moving over them, so there is no venturi effect and they depend solely on convection. Active air movement from a fan or fans would help them perform as intended. JMHO
Very interested in how this works out for you. I proposed the use of bilge fans for this purpose several years ago.
Is there any way to duct it rearward, and have the movement of air from the rear tire kind of help suck it out of there? :dontknow:
Once I get the fan and materials, I'll start experimenting . . . I am enthusiastic that this is solvable . . . If this solution works, (and it appears it is working for the poster who is using the fog light openings to bring in air) the next step would be a better fan, designed for constant use, with a temperature controlled switch.
