Originally Posted by
ByeSpyder
I can readily name at least a dozen cars manufactured within the past two and a half decades that were "Yugo" like. If you want current examples consider the SmartCar and anything by Fiat. American manufacturers are not exempt either. GM's diesel powered sedans, the pseudo Chev/Cadillac, Pontiac Fiero, Chevy Nova....the list goes on.
If the name "SpyderLovers" suggests the only admissible topics are to praise the Spyder then someone should publish the reason for the site's existence. Otherwise, I assume, as would most people that all discussions relevant to the Spyder are eligible for discussion.
I owned my Spyder for a bit longer than one year but if I had found this site prior to buying it I would have passed on the purchase. Most people know the story of any German-made luxury car - the high maintenance costs and very troublesome nature of the overly complex operating systems. I found the Spyder the Can-Am equivalent. I could list dozens of individual items but here are a few basic ones which Can-Am could have fixed simply by reading the posts on this site:
Incredibly sensitive brake and oil levels throwing limp mode codes when no real issue exists.
CANBUS - need I say more?
Weak windshield supports
Cost/ease of simple maintenance (oil change being the main culprit)
Incompetent dealer service departments and techs and need for non-available diagnostic tools for owners
Incompetent audio and CB (not even going into the difficulties with the 2018 dash)
Need for post purchase alignment, adequate sway bar and shocks
Kenda tires
Difficulty checking/airing rear tire
Note: These are not necessarily MY personal issues but those I have gleaned from the many posts on this site.
A motorcycle-type vehicle costing over $30,000 new should excel at both design and maintainability. The Spyder falls very short of that standard. I have owned dozens of two-wheelers over the years including some very labor intensive British marques but none of them have even come close to the absurdity of the Spyder.
And regarding Can-Am's other products - someone mentioned Sea-Doo. I was doing some intensive research a few months ago on PWC's and was not impressed by the Sea-Doo line when compared to other manufactures. While some of their models seem to perform very well, especially in salt water, their turbo engines have several very weak areas including the use of porcelain washers which fail frequently and cause catastrophic damage to the engine. This type of design failure is inexcusable. The bottom line is I see similar systemic discrepancies in the design, manufacture and support of their PWC's that I see in the Spyder. I will never touch another Can-Am product as a result.
