I'll provide you an update this week with photos showing the Spyder RTL on the trailer with hitch on...we'll see what happens!
Printable View
I have an Aluma 6810 HT
It tilts
Will be transporting my RTL with trailer hitch this Thursday. Will try to remember to take and post a picture.
Cappy
Yes, it will fit with the hitch on. However, the end gate does not remain vertical as it has several positions in can be locked in. It's at a slight angle backwards in the first hole from vertical. I just installed the hitch on my Spyder RTL and wanted to know this as well - I hope this helps you! :thumbup:
Some pictures from today for you:
Pic 1: Loading RT on Droptail Trailer with rear part of trailer hydraulically lowered
Pic 2: RT on trailer, still rear part of trailer lowered
Pic 3: RT on trailer, rear part hydraulically raised and locked
Pic 4: Rear end gate raised and one hole from vertical position (normally vertical without hitch bike), shows clearance to hitch's mud flap
Pic 5: Another clearance shot showing where the rear end gate is in relation to the hitch's mud flap
Been following this thread and am confused on how people tie the bike down on the trailer! I have a flat bed aluminum trailer with single ramp and I have a F3T. I usually go up to the local school and drop the ramp down on the curb and the bike loads and unloads real easy but not sure how I should tie it down!
I always ratchet strap down the Spyder on the trailer when travelling - two straps with protectors through the front wheels to frame of trailer. One strap on back tire with protector sleeve. I purchased the Droptail ratchet straps when I bought the trailer and they are very good! The only time it sits on the trailer without it being strapped down is when it's parked and just sitting still on the trailer.
We bought the 18' from Shadow trailers in Ocala Fl. We have pulled it with our Dodge Journey with the RS and St on it, without any problems. Now we have 2 F3L and we are now pulling it with our Dodge 1500. We had it up in the Mountains without any problems.
We were trailing in WV and Eastern KY. It came with 3 ramps, two of them are under the trailer in front of the front axles, the 3rd is like the bulk head of the trailer (front). It only takes about 20 min. to load or unload. We will have it in Quebec if you want to see it, we will be staying at the Best Western at Drummondville. John and Carol
,oops I see you were able to fit it on from a later post. :opps::thumbup:
Or maybe just measure to see. :thumbup: I see you got this version Drop - Tail "Two - Up" Cruiser / Sport Bike Trailer, model number: 03-DCT2200-02instead of Street Pro 2200 PowerSport Utility Trailer which shows an RS on the trailer. Why? Does look like yours has more features though.
Trying to post the pictures. Seems like they are here now😆
I just bought a Triton AUT 1272B (bifold) I will check out loading the Spyder, bought it to haul my SXS? I use something called a soft strap hauling the SXS, it's a strap with loops on each end that keeps the ratchet binder hooks away from the machine at your tie down points.
We have an Aluma tilt trailer we use to haul our Spyder - the whole deck tilts [the Spyder nose doesn't drag loading or unloading].
Tilt the deck, ryde the Spyder on, the deck tilts back level and locks - then tie it down and drive away. I can load and unload the trailer all by myself!! It's a breeze.
We bought it in Litchfield, Illinois at Midway Trailer Sales; model #7712 HTILT.
Has anyone used the Aluma TK1? I am considering one to haul my RTL behind the fifth wheel. I saw a video of someone loading a Spyder on one but I don't think it was a RTL, worried about the front cowling.
I was looking into theStinger folding motorcycle trailer, they make one specifically for the Can Am Spyder but it does not have a rock guard on it.
Here is the website for the trailer.
https://www.stingertrailer.com/produ...pyder-trailer/
This is the setup that I use only tie off the front doesn't move at all, no scratches on wheels (straps thru socks). Towed for many miles this way. Bi-fold ramp works great.
We have a Forest River 7X12 enclosed aluminum trailer. It weighs 1300 lbs.. Great for hauling the Spyder. And the Spyder is out of the weather, safe from problems when parked. We were parked right behind Mike T at the BWCH+ when all the problems happened. :thumbup: Tom :thumbup:
