Lamont does have a installation video on his fog lights....I believe it is on his Website....or maybe it was on YouTube....but there is on.
Printable View
Sorry, thought you were talking about the Fog Lights. Yes, the top of the bike needs to come off to get to the headlights. Note, when you remove the upper panel under the gauge assembly and windshield mounting area the wiring harness is attached to it and zip ties must be cut....be careful not to cut your harness....I did not re-assemble mine the same....I zip tied to other areas so if I ever remove it again I won't have the hassle. You are correct about BRP making it a pain to just replace headlight bulbs. Right side is easy as there is more room for your hands but the left is a pain.
They are a little bit of a pain to change the headlights. If you take your time and go slow, it's not hard, just a pain. One thing I noticed when I put mine in... make sure the bulbs are oriented correctly in the housing. The Lamont kit comes with a little allen wrench to adjust the bulb orientation. If they aren't oriented the same on both sides it will project a different beam pattern from one side to the other.
Also, Lamont didn't make a video of the install because of how long it takes. I read in another post on here somewhere that he tries to keep his videos around 10 min or less. If you can change the headlight bulbs in under 10 minutes... :bowdown::clap:
I found that doing the Headlights were much easier then doing the fog lights.
I cannot answer your question if Lamonts headlights are better, but I really like them. They seem to be really high quality and soooo much brighter than the oem halogens and combined with the fog lights they not only light up the road really good but they look really good also.
Like a few people said it is a pain, a few drops of blood because the left side doesn't have a lot of room(tip use hemostats to remove and replace retaining clips that hold the bulb in,make it easier, especially on the left side.. wife's idea worked great.) The Lamonster Led headlights are installed.:yes: Thanks for all the tips, they sure came in handy! :clap::clap:
I just installed the headlights from TricLED last night. It was a pain to get to the headlights but well worth it once the installation was finished. Now the light from the headlights matches the light from my LED foglights!! Much better than OEM's!👍😄
Too funny so did I....
http://www.spyderlovers.com/forums/a...d=130216&stc=1
I purchased the BRP fog lights for the F3 then I changed the bulb to an LED bulb so that it would be a bright white light not yellow.
To all that chose TricLed products.. Thank you very much! For the past 6 yrs, we strive to deliver the best in LEDs and stand behind our products.
I have the F3-T, I noticed in this picture there is a "high left" flair mine has that too. I started with both bulbs level with the horizon. How many hash marks did you rotate each bulb from level and did you do both in the same direction. Love the lights but getting the bulbs rotated to right angle seems to be alluding me. I hate to have to go to trial and error. Thanks in advance guys.
I also noticed the poorly aligned beams in the photo. What is up with that?
I installed the Cyclops Adventure Sports bulbs and they are super bright, easy to install on our RT, and no beam misalignment.
Is that misalignment unique to the F3 headlights?
I have not had time to align them yet. (I should have mentioned that):opps:
I also have a loose housing on the left, even with the stock bulbs when lowered to correct height it would bounce. I had it set a tad high to keep it tight, it is was more noticeable with the LEDs. I need to have my dealer replace it under warranty one of these days. I tried everything to fix it but I think it's just a defective housing.
Are these plug and play?
[QUOTE=wolfeman220940;1131366]Are these plug and play?
Sent from my iPhone using Tapatalk[/QUOTE
More like a lot of disassembly, hurt knuckles, PLUG, swearing, reassembly, then PLAY:roflblack:
