:thumbup:
Printable View
I hadn't given that one any thought, but I'll check the numbers for US ... stay tuned .........PS I think Peter Aawen or Peteoz . runs a 65 aspect tire ...... Mike :thumbup:. OK I did some research on this size ..... I used the Altimax RT43 for comparision because they have a number of tires exactly and similar in size ..... The Quatrac 5 in 205/65-15 is only a Hair different than the Altimax in 215/60-15 and we all know that Altimax FITS all Spyders ...... So my answer would be ..go for it:yes::yes:.....the actual width difference between a 205 & 215 might be 1/4 inch ......hope this helps ..... Mike
Mike, I sent this to Peter as well..I value both of your opinions and trying to figure this out.
I found that Vredestein also produces a 205/60R15 91H or 91V What do you think of these choices? How will they affect the speedometer and odometer and Nanny?
For the fronts I found 165/65R 81T and 165/60 R15 77 H. Should I match up the 60s ? Your thoughts on this combo?
Thanks again for all your input!! Jeff
Does anyone use runflat tires ,had one on the rear off the Wing worked good ,but never had a flat. But just felt safer with it on.
One thing I will throw out here, is that when I installed my Kuhmo KH17 175x60 fronts, my speedo trued up. It now matches my GPS speed perfectly. This was BEFORE I had installed my Kuhmo rear. Peter A couldn’t understand this, which caused a lot of self doubt, but after checking everything again, there is no question that the install of those size fronts, definitely trued up my speedo.
......and the install of a KU22 205/55 rear, did not alter it .
Pete
Immediate difference.
This is all subjective based on the car tire you choose... but with the right car tires I've:
Had way better dry traction front and back
Had way better wet traction front and back
Had way better standing water performance front and back
The Kumho that I tried on the rear of my GS lasted 11k miles - about 1k more than the OEM Kendas. The Kuhmo was a fine touring tire, but overall it's dry and wet performance was pretty bad. Only benefit of the Kumho for me was even tread wear across the entire tire width.
On the GS fronts the Bridgestone Potenza RE-92's were absolutely awesome.
On the GS the best rear I had was the Toyo Proxes 4 (no longer made). That tire was super sticky in the dry and it's wet and rain performance was incredible. Between a nail in one Toyo and selling the GS I never figured out what miles I could get to with the Toyo (on the GS)
On the F3-S I switched to the Federal Evos for the fronts. Did it early. Bit stickier than stock and better in the rain. I switched out the Kenda fronts at 4500 miles and to be honest I would have been ok keeping the OEM fronts, but decided to switch early.
On the F3-S rear I have once again a Toyo Proxes 4. My OEM Kenda was ready for replacement near 4500 miles. After 5500 on this current Toyo it looks like I might make 8k miles before needing a new rear. So I'm not getting great mileage out of the rears on the F3. I chalk that up to riding style. My Spyder doesn't do low heat around town puttering. When I ride I'm out for 8+ hours a day of riding twisties with hard braking and acceleration. No burnouts other than some wheel slip now and then.
Best advice? Any car tire is going to perform better than the Kendas and wear evenly. You may or may not get more miles out of the rear specifically. The Kumho is fine for many, but I suggest spending the extra $ on something better like the Yokohama s drive 205/50R15. It may even be in the same price range but people seem far happier with the Yokohama than the Kumho.
As for air pressure I'll only say you will find lots of opinions and a lot of apparent tire experts here. Yes the Spyder is lighter than a car and thus the tires aren't even pushing their load ratings. I've run 20-22 PSI on the fronts for thousands of miles with no issues and anywhere from 28-30 on the rear with no issues. You go too low of a PSI and the tire may create too much heat via sidewall flex and may break a bead in an abrupt swerve. Some here suggest some very low PSI in the tires.... "Tread" carefully... Get it? :)
I buy mine for performance and not price and not the miles I get out of them. True, I wish the tires would last longer on my F3-S but that is probably my fault more than anything else. Just remember that at some point after your 2nd or 3rd rear tire you should have your rear bearings inspected and potentially replaced.
I will be mounting my last Toyo Proxes 4 this summer at some point... I really wish they still made that tire.
Dan, in all the Car tires I have used ( for the rear ) ...they have been in 16 to 18 PSI range ....well over 100,000 miles of riding ...... I have never had a tire even SLIP on the Rim let alone break a BEAD ....Over-inflating a Car tire ( for the Spyders weight ) is #1. - giving you less traction ...and #2. - a punishing ride..... This is tire Science not " what someones Butt told them " ...... To ALL those tire Science doubters just try this ..... On your Spyder , deflate a tire to about 5 psi ( this won't break the Bead on a parked machine ) ... now start IN-FLATING it, you can Actually see the tire FOOTPRINT getting smaller ....this begs the question - How can a smaller Footprint give better traction - Answer IT CAN'T..............and if you think it CAN - then you should " PROVE IT " ........ Mike :thumbup:
Prove what? What exactly are you asking me?
The answer is simple. At the same tire pressure the car tire will out perform stock kendas. You want to go lower fine, that is choice. I don't know how you ride Mike. I've met a lot of people that say they ride their spyder hard and then end up riding with them and find out their own perception of their riding style is not anywhere near reality. I've seen some people here suggest some pretty low psi numbers which quite frankly probably weren't safe for all riders and situations.
I'm well aware of what air pressure does for tires. I run my rock crawler at 3-5 psi per tire for traction, but I have dual beadlocks.
Again... not here to get in an internet pissing match.
Dan I WASN'T asking ...YOU ...to prove anything AND I wasn't asking YOU ( personally ) .....anything .... the - " and if you think it can - then you should " PROVE It " ...the you here was generic for all the Science doubters that are extremely vocal and negative about Science ......... So you pretty much mis-understood what I was trying to convey :banghead::banghead::banghead: .......... When / if I decide to have a fight - I rarely start out by HELPING that person , which is what I was trying to do for You !!!!! ............... Mike :thumbup:
i use vredstein quatrac on my '13 rt-s and they are very good tires in quality and performance
I run 25psi up front and 28psi in the back. Ride every day and experimented countless times, and measured heat signatures.
I personally do not like the soft shoe feel of 20psi, and 15psi was like a wet sock trying to just turn in my driveway. Just not for me and others that I know.
Curiosity, but did you track and measure the heat differentials at differing inflation figures?
Many people actively advocate for lower inflation figures, but have not posted any temperatures. That's the biggest potential problem with under inflating the tires is heat build up. The old rule of thumb was to measure the temperature of the tire when cold and then when run up. If there's more than 2-3 psi difference, then you're under inflated.
