As I have asked many question regarding the Customer Accessory Circuits and how to install a GPS, I thought I would just do it. So, this is how I did the install of a Garmin 595LM (the up to date version of the 590 which is sold by BRP).
I used a handlebar mount, all included with the Garmin except for the long reach RAM Long Double Socket Arm (6"). I mounted the primary attachment using the bolts supplied and attaching it to the base of the left hand Grip/Handlebar clamp. The 6" arm attaches to this, and the Garmin mount for the 595LM, to the top of the arm.
The wiring is the most interesting as I could not identify the middle Customer Accessory Circuit wires until I had removed the left side panel. Then one can see the friction tapped wires hanging down, and once the tape is removed, gosh there they are, a black ground and purple/white hot wire (Hot when engine is running). Here is a photo showing the wire after I placed shrink tubing on the end of the remaining friction tape so as to keep it from unraveling.
https://c5.staticflickr.com/9/8119/2...fbda56aa_z.jpgZumo 595LM Installation_09.11.2016_TFL-2 by
Tommie Lauer, on Flickr
As I wanted additional options should I decide to add more powered stuff, I added to plug in ends to this accessory circuit, as shown:
https://c3.staticflickr.com/9/8276/2...3b99dd54_z.jpgZumo 595LM Installation_09.11.2016_TFL-6 by
Look carefully and you will see the purple/white hot wire and all the connections.
So, what does one do with the huge amount of wires from the Garmin mount? I simply folded them up and tucked them away, Zip tying to a part of the roadster. I did not want to cut any of these at this time.
https://c1.staticflickr.com/9/8099/2...6a1aaaeb_z.jpgZumo 595LM Installation_09.11.2016_TFL-7 by
After all is said and done, the cable from the Garmin mount zip tied in place so as to avoid any chafing when the handlebars are moved, I mounted the Garmin and it actually worked.
https://c8.staticflickr.com/9/8455/2...1a65b513_z.jpgZumo 595LM Installation_09.11.2016_TFL-8 by
Oh, on the handlebar mount some small shaving of the pacers from Garmin was necessary, but no issue for those who do this stuff on a regular basis.
If any questions .... let 'em rip.
