my center bracket on my windshield broke today,octane outlet of eastgate told me I have to buy the entire motor assembly for $600.00.i was hoping for a less expensive solution,any help would be greatly appreciated,thanks.
Printable View
Hi Im In Australia And On our forum We Have A Guy Thats Made Up A Machined aluminum Pivot Bar With instructions And Special Wedges.
My rt ltd didnt have any issues But I Was Doing A Led conversion To Both Light So I Was nearly At The Screen pivot Anyway.i Changed It To Pevent Breaking while On A cruise.
His Forum Name Is Tripod, Search That He Might Be On Here.
Its a great kit.if your handy with Tools you Can Do It Yourself.
Its ozspyderiders.com.au
Cheers stu.
Pm noboot
Sent from my VS990 using Tapatalk
Send a message to noboot on this forum.
http://www.spyderlovers.com/forums/m...p?11127-noboot
Here is a potential solution for you
http://www.spyderlovers.com/forums/s...illet+aluminum
This one of the best post to help each other to maintain our :spyder2: thanks.
His version of the cam is 1,000% sturdier than the OEM. Ends up costing less. The shop installed it for me in a couple of hours! Get one NOW!
~Sandee~
PM me... I've got one here, that you can have until the replacements are available. :thumbup:
thanks everybody for your help, randy
[QUOTE=noboot;1177866]I currently don't have any possible for 3 or 4 weeks.
Maybe one of the guys on here can send (lend) you theirs that they are holding in their tool kit and you can replace it once I have them available.
Just a thought, so if anyone can help[/Q:ohyea:UOTE]
thanks noboot,member is sending me one will replace when they become available.be in touch.
:agree: It's being handled... :thumbup:
Just a reminder from the "Do's & Do Not's":
Check your windshield brackets often:
They have been known to fail occasionally. The consensus is if you run with your shield "full-down" most of the time, it will cause undue stress on the middle bracket, which raises and lowers the shield. Move the shield up slightly off the metal-stop to avoid the potential damage. Keep in mind you cannot replace just the bracket. The entire lift-mechanism has to be replaced to the tune of around $600.
