Harbor Freight Cycle Lift
Do those of you that have the Harbor Freight cycle lift that is now on sale for 69.99, feel that you use it enough to have bought it? I want to get one, but not if it is only going to be used once in a blue moon. Only thing that
I could think of using it for is changing brakes. Not sure since it is under the center of bike if you could change oil, or what ever. Just curious. Don't want to buy another piece of equipment to take up room in the garage, since
I had to get rid of stuff just to make room for the Spyder. If anyone has a picture of exactly where to jack up, it would be appreciated also.
I have a 2010 RT.
Thanks
You can never have enough tools....
I use that kind of lift for many jobs. Strangely not for oil changes. But even for cleaning it works well. I also do all my own work. Now if you only wash and do oil changes you may not use it that often but will miss it when you need it. :thumbup:
Here's my two cents worth -----
I sadly bought one of them thar du hickey's from Harbor Freight thinking I'd be doing stuff to my Spyder. I have ONLY used it ONE time- I say- ONE TIME! and that was to put RIDE ON in my tires.
Catch a good sale at Harbor Freight and if it does sit around you won't be sick to yer stomach like some of us. (SMILE)
I now have a 2015 RT Limited and when it cools down again outside, I might use that thar lift again to put RIDE ON into this Spyders tires.
That was and is my experience. :D
Good luck in your decision making!
