just got the air scoop kit no introduction who know how they should bolt to gather and where to cut panel
need some help .....
Printable View
I sent you a PM.
Just did mine with the help of Doc's guide. If you are afraid of the marking part call your dealer. They probably received the install kit from BRP withe the marking templates. My dealer offered to mark them if I brought them in. I was going to but in the end followed Doc's detailed instructions (with a few liberties) and all went well.
CJ JAX
With all the talented people on this site i would of thought someone could design scoops with some style. Something functional yet classy. Like the scoop on a 1971 barracuda. I may have kept the 13 if BRP would of thought about appearance as well as function.
Like the Looks OR Not- They lower my Temp from 5 Bars to 4 on a 90 Degree day and I am running 2 Bars in the late fall and winter- I think the engine may freeze up????
I said 3-4 Years ago that those acoustic Panels were CAUSING the heat problems because they COVERED the cylinder heads and Created the heat in the gas tank and crouch Area?
Finally someone listened ???? Now you hear More engine noise BUT your running Much cooler !
that.
I don't cut anything i use the already hole and i remove only the grill , with the scoop the air is force to go inside... when i install it i would not want to mess with cutting anything i try it like that it reduce 5 to 4 bar so i decide to leave it like that.
I just completed painting the Scoops on my 2012 looks a lot better with out that black mass on the side on the bike.before / after all the info in a thread here see (painted air vents)
i ask my dealer about those scoops for wifes 2015 she complain about heat he said he checked with brp told they not fit her rt
Hi fatboy i was just looking at some 2015 rt's and it sure looks like they would fit to me the 2015 has the same air deflector and small vent that my 2012 had before i installed the air scoops. maybe you could start a thread and see how many have installed them on their 2015's
I like the look of my just being black it go good with big blue...:firstplace::yes::yes:
I have them on my 15 RT and they fit fine, look pretty nice, and certainly work. (keep the center section of the Spyder much cooler on the HOT Florida days.)
David
What would the part number be? Thanks
Do a ssearch for "Doc Riverside" and you will find all the information you need to get the kit, and do the installation.
David
Got my scoop kit in this week. Hopeing to pdf.file from Doc. Soon.
