Thanks!
Thanks!
1/2 hour or less, straightforward job. :doorag:
You don't need to remove the seat to do that.
Don't need to take the seat off for the backrest. Need to be off for the seat skin. Best to do both at the same time. I need to take apart my sport rack to get the seat off for the seat skin. LOL
Answer is yes. You need to unscrew those 4 bolts to take to top part of the sport rack off so you can raise the seat to its vertical position (after unhooking the gas shock and deteach the seat sensor). Once vertical, you can get at the three bolts holding the seat down.
The easiest way to remove the seat is to do the following
1. Remove the reatining clip at the top of the gas shock. Then remove the single blot at the rear pivot point of the seat. This can be done without removing the Backrest or the Rear rack.
Once that is done then you have easy access to all the bolts under the the seat, including the actual mounting bracket.
Unless installing the BRP sport rack changed something, that single bolt at the seat pivot is captured by the grab rails. When I installed my Russell seat, I was unable to get that bolt out until the seat mounting plate (4 bolts) was removed from the Spyder.
I just took my sport rack apart last monday for painting, after you remove the 4 bolts, there is two other tiny bolts that separate the rack in two parts plus 1 other under at the back of the fender, once all these bolts are out, slide the under piece out so you can get access to disconect the
cable that releases the back rest, once the cable is out you could completly remove the rack
hope it could help :thumbup:
Finally, my Spyder is home after being at the dealer for 9 days (service / exhaust gaskets - these had to be ordered).
I installed my Nelson-Rigg bags this morning. Nice fit! Then, I removed them since they will only be used for overnighters, etc,,,. Now.. the only thing I have to do is install the new seat skin.
I removed the plate off the sport rack, and loosened 2 of those bolts down inside. Then, I tightened them up. I'm going to attempt to remove the seat without taking that back section off.
But,,, another day.
Why is this discussion in the F3 thread? Ya'll are describing seats that pivot: they were never on any of the F3 models. The passenger seat pops off via the ignition key turn. The rider seat is held on via two 10-mm headed bolts. Both can be removed with a passenger back rest installed. The rider back rest simply pulls out of its socket.
Did you check the dates of the First Post in this Thread pauly?? Or did you look at the dates on the last few posts in it before you posted up in reply to this thread?? :dontknow:
Somehow, despite the frequent reminders that the Mods do post to this effect, I doubt that you did.... Cos if you HAD, then you'd probably have realised that this thread was started waaay back in 2009, well before ANYONE had an F3, so rather than it being POSTED in the wrong section, it was more likely just mixed up in the re-shuffle & subsequent re-organisation that happened once F3's finally DID come along, when the Forum Sections and sub-forums were re-organised to reflect that! ;) Buuut, this sorta stuff does happen at times, and the fact that Otter still felt it appropriate to thank an earlier contributor to the thread, joespy, because the info in their post helped otter sort their own issue should be applauded regardless of where it occurs or how long after the original thread was posted!:ohyea:
If you'd realized any of this, then I'm sure that you would've decided that a more appropriate course of action for you to follow would've been to either PM one or all of the Mods to ask us to move the thread into the right sub-forum; or you could even have clicked on the little exclamation mark in a triangle that's down in the bottom left of any of the posts in this thread to Report the thread and so bring to the attention of ALL the Mods that this thread somehow ended up in the wrong sub-forum, probably back in 2015 when F3's first hit the streets. Either of those methods would've seen this thread moved to the correct sub-forum without you having to post anything like you did and run the risk of being labelled as a bit of an aggro **** who's getting all picky about where a thread was originally posted waaay back in 2009; or how it must've got moved into the wrong section/sub-forum probably some-time shortly after the advent of the F3's back in 2015.... :shocked:
Just Sayin' :thumbup:
