Finally Got the Nanny to Slap Me!!!
It took some work but this is what I did on my 2012 RT:
I normally lean into turns, this is a habit. It helps keep the wheels on the ground. I normally turn onto the street that I live on, it is about a 100 degree turn, I normally take it at about 30 MPH. I lean WAY over to keep the wheels down. So today I said, "What the heck! Let's not lean." (I didn't really say "heck", but you get the idea.) So I turned. I did not lean. ...the nanny powered down and slapped me. I was watching the wheels, and it didn't look like the inside one lifted off the pavement.
So I went around again. Same speed. No lean. Same results.
So I went around again. Same speed. Lean like normal. No Nanny.
Interesting...the Nanny likes you to "lean into it." (heh).
Lifting inside front wheel
I don't know how smooth you need to be to lift a wheel in turns, but I did manage to do it today. I just recently bought a 2011 RT and have put about 200 miles on it. Still getting used to the extra wheel (my previous ride was a '07 DL650) and I guess I was carrying too much speed into too tight of a corner (about 100 degrees). Applied throttle too early and up went the front left wheel. It was surprising but not scary. Not sure if Nanny kicked in or just rolling off the throttle saved my bacon. The best part was upon my wheels return to earth I was greeted by the sight of a white-bearded Harley rider giving me a thumbs up. :2thumbs: Has anybody else managed to pick up the front wheels while taking a turn?
