Is it normal for tires to wear the middle first? Mine are completely shot in the middle but the outside look good. It's got 9,500 miles on it. I've kept the pressure at 28 since I've owned it (New to me at 5,000)
Printable View
OVER INFLATED.....
drain some psi out'a that sucker....
agree -- over-inflated
You are definitely the victim of over inflation. But you may not have been the cause of it. Best to check your tire pressure gauge against a known standard for accuracy just to be safe for the next tires longer life span.
Nope not over inflated, The stock tire is quasi motorcycle tire, And will expand [balloon] at speeds.
Crazy as it sounds that type of ware with the stock tire is normal...
I absolutely agree about the "balooning effect". I kept very good track of the air pressure in the rear tire and it would wear out in the center with a lot of tread left on the outer edge of the tire. I would have to replace the stock tire around 12,000 to 14,000 miles on it. I have over 28,000 miles on my Michelin and looks like I will get at least 30,000 miles on it before I have to put my new Michelin on.:thumbup:
the man is right!! just replaced mine at 10,000 and it looked identical.(worn into the wear bars) the spyder tech at my dealership explained the dynamics of it, coupled with a two ply and that's what you get!!! unfortunately I replaced mine with the same, because I have heard some horror stories about warrantee work on trannies etc. not being covered with off label tires on the roadster.:yikes: didn't want to take the chance.done last week, $223.00 tire and labor! I ran mine the whole time at 24 to 25 and I still got the wear!
Owners manual says 26-30psi
Over- or under-inflated; these tires are famous for wearing out the center section... :gaah:
Same thing happened to me, got 8500 miles on it. I tried to lower the pressure on it and it didn't do any good. When the dealer asked me if I did a lot of highway riding, I told him I did not and asked him why he thought to ask that. He informed me that at "higher than normal speeds" the tire would balloon and wear out the center. Sounds to me like somebody has been playing a bit hard.:2thumbs:
Just sayin'............
It is normal for the Kenda tire. The ballooning problem gets worse as the tire wears. It is also worse at freeway speeds. Pressures within the recommended range seem to make little difference.
Similar situation for me. I just replaced my rear tire and am now on tire # three. I average 13,000 to 15,000 miles on a tire. Keep inflated at 28psi. Same wear pattern on mine as shown above.
I've got a Toyota Proxes waiting for me at home. My Kendall is shot at 12000 miles worn in the middle. I just hope it gets me through the week until I get home
205/60/15 (the next size bigger would have cleared ) Michelin hydro edge 90,000 mi rated its a discontinued model but they are still out there it's a great tire in rain it's going to wear very very well I tried a Toyo proxies and it didn't do any better than the Oem
:shocked::shocked:http://www.spyderlovers.com/forums/a...661258&thumb=1:shocked: :shocked::opps: This is what 21K looked like for us :opps:
http://www.spyderlovers.com/forums/a...1&d=1327030975
http://www.spyderlovers.com/forums/a...1&d=1327030964
http://www.spyderlovers.com/forums/a...1&d=1327030953
:ohyea: We have now switched to General Altimax's all around :ohyea:
http://www.spyderlovers.com/forums/a...4&d=1366043079
Dave...
That's not "completely shot"; that's dangerous! :shocked:
The Michelin HydroEdge is discontinued, but can be found at http://www.tirerack.com/tires/TireSe...60&diameter=15 (closeout) for $111.00. I used the 215/60R15 size and found that my speedometer is now always within 1 mph of my GPS, often showing the same speed. No nanny issues since I mounted it March of last year. Also had the O-rings, spacers and seals replaced while the dealer mounted the tire for me.
