I would like to see if anyone has used the wireless tire pressure monitoring kit from Big Bike Parts sold by Show Chrome. They show a regular trike but the number one cap goes on the single front tire. Has anyone used these before?
Printable View
I have there 4wheel model from my old Goldwing, bike plus trailer.
I put the two trailer caps on the front wheels and one of the bike caps on the rear works fine.
they have a spyder model out now, just the LCD is different, want them to make spyder plus trailer 5 wheel system
harry
live from the uk
Thanks for the come back and I just off the phone with a buddy who owns a Goldwing and he says you can use any number any where you want just remember which one is where. Thanks Gary
Harry,
How accurate is that system...(Comparing it to the BRP's supplied gauge), and were there any issues with the balance of the tires?
Bob,
i think they were referring to this http://www.cruisercustomizing.com/sh...rt/BBP-13-316A
not the one that comes in the spyder tool kit
I have been using the TireGard Trike system for a couple of years on my RTs. Works great and no tire balance issues. The remote control vibrates if the pressure in a tire drops below the programmed level. I think there are some cheaper systems around but this one is very well made and reliable.
I have TPM monitors that are made for the can am. They work great and do not cause a balance issue. The company is www.Tpms.ca. There are about two hundred plus shipping.
OK I knew where the tool kit is but never took it out and looked inside as I have my own tools.
So I found the digital pressure gauge. However does this thing work properly?
I tested it and found the following issues
1) It reads about 2 PSI higher than my "pen style" analog gauge. So which is right? As confusious says "Man with too many pressure gauges never knows the correct PSI" ;)
2) If I hold the gauge on the stem, the readout keeps climbing! WTH is up with that? I held it on my front tire and it kept climbing to 37 PSI before it stopped increasing!
Am I doing something wrong using this thing or is it just a POS?
Bob
I dunno...
Mine just gives me a consistent number... :dontknow:
Glad that you found it though! :thumbup:
One word of caution -- the fine print from both these manufacturers says not to use them with rubber valve stems. For the Canadian outfit Hawkshead (tpms.ca), it's item 14 in their FAQ's. A "chat" with Big Bike Parts (Tiregard) confirmed the same for them -- they don't recommend using with rubber stems. Some of the other manufacturers are more upfront about that recommendation. Doran tells you not to use rubber stems and even provides straight and 90-degree metal valve stems with their systems but I don't know if they would fit on a Spyder.
I've thought of installing these on my RT and my Gold Wing but any even slight possibility of causing premature valve stem failure kind of defeats the purpose.
I have only had mine on for 4 months now with no problem.
