has any of you bikers when shutting down your bikes heard beep beep beep, what the beep does this mean ?:yikes:
Printable View
Can't say that I have experienced that one yet!
The parking brake alarm does not go beep, beep, beep.
it goes blare, blare, blare and will wake the dead three cemeteries away from where your parked!
I would guess you do not have your park brake set. It will sound a warning alarm when you turn the key off with out setting the brake. However, after several seconds the alarm will stop. I do not set the brake when parked in the garage, as I have to move it back and forth. I do make sure that the rear wheel is chocked.
It means you neglected to activate the parking brake on an SE. The parking brake must be set or the Spyder can roll away.
fast and simple but now you know..all those little things many miss in the manual but thats why we are here to help...:ohyea:
...Watch for the flashing red light in the analog speedometer display... If ti's not flashing, you'll sound like a telephone company work truck that's backing up... :opps:
thanks i will remember what u all said:ohyea:
