I'm going to put a new tire on the rear and was wondering how to balance it. I'm no where near a dealer so i'm taking it to a tire shop. The hole doesn't look like it will fit on the balancing machine.
Printable View
RIDE ON TIRE SEALANT, They are a sponsor, CAN CONFIRM it seals the tire, HAVE not confirmed it will balance. Hopefully will find out in the next week or so, as I also am getting the rear tire replaced, it comes off the SPYDER tomorrow and into the tire shop Tuesday.... With today's snowstorm, hopefully should get a ride in this weekend...
I used Counteract Balancing Beads On my fronts (2 Onz) and they work great.
Will put 3 onz In rear when I replace it soon.
:clap:
Ride on will definitely balance your tire. Make sure to order the auto formula, not the motorcycle one.
Don't think that balancing the rear tire is a must... More a marketing hype!
I will look into the ride on, I take it can be added through the valve stem on the bike? As for not worrying abou balancing, should I take the weights off that we're on the stocker or just leave them on?
Take the weights off when you have the new tire put on--- then put Ride-on in thru valve stem-- they give you a kit to do it when you order.
18 oz for rear tire.
11-13 for fronts.
Works GREAT.
More info:
http://www.spyderlovers.com/forums/s...t=ride+sealant
