1 Attachment(s)
Help: Can you identify these brackets?
I've found a pair of brackets under the front fascia, left hand side.
See photo. I've color-washed the brackets yellow to make them more obvious.
Together they obviously hold something about 4.5" wide.
Anybody know what the missing item is? :dontknow:
Use for mounting bracket...
SOMEONE needs to come out with either a machine gun or rocket launcher to fit there, for those who pull out in front of you!
4 Attachment(s)
Brackets for additional Fuse Box
Ref those Brackets - I have found a use for them
I have fitted an additional Fuse Box - FZ-1 - .See http://www.fuzeblocks.com/
I have connected a Power socket, Running Lights, Clock and Voltmeter off it - all fused
The problem was where to locate it ?
It had to be easy access to allow for any changes (Adding more accessories) - Replacing Fuses if needed and
also the runnning of wires etc
A Location where it would not get too hot _ Difficult on the Spyder RT - S
and would not be prone to failure due to the weather
Having looked at the those brackets and their location and with the size of the FZ -1 Fusebox - this was my chosen location
I found the location ideal for running wiires to either side as the Fusebox is on the RHS (Looking from the front)
any wires needed for the LHS run under the lights behind the Front trunk (Plenty of room)
I fixed the Fusebox with Heavy duty velcro and Zip ties which hold it very secure - it has extra wire which allows me to pull it out when I need to
Although the fusebox is under the RHS Service cover I have added extra sleeving to protect the wires and made a rubber sheet which covers over the top of the FZ1 - Fusebox stopping any Water/Dirt etc
I have been in 2 storms and not had any problems
I have posted some photos as this may help others
Eddie Sheppard
Reading Uk
Spyder – RT-S SES (AUTO 2010 Model)
List of Mods :-
Added Zuno 660 -Garmin kit as supplied on the Spyder RT Limited
Digital Voltmeter and Digital Clock to replace Fuel and Temp gauge – Fuel and Temp now
displayed in Cluster Display
LED Bulbs Reversing Lights,Front position lights
HMT - Brake Light
LED – Running lights
LED - Mud Flap lights
Rear extended Mud Flap
Sport Tall Wide Clear Windshield
Utopia Backrest
S/S Grills both sides matching
Bottom Panel S/S Protection
S/S stronger Funk Lid brackets
S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
Rubber Tank protector on glove box
Grip Puppies
Power Socket in Switch Cluster and at Rear passenger Handrail
Rear Speaker Switch for passenger On/OFF
Upgraded Front Marine Speakers
Bluetooth On board Radio to Sena SMH10 Headsets
1 Attachment(s)
Somebody wanted machine guns ?
