Please, I need help with an electical issue.
First I'd like to say thank you for checking this thread.
I have LED's fender tips and mud flap Led's from ESI. They have been on my bike for about two years. They are of the highest quality, and, I have had no issue with them.
The issue I have is, my right mud flap suddenly stopped working. Then I notice that my fender tip on the right side was very dim. My first thought is the LED was going bad, and that my wiring had a short in it, going to the mud flap. No that was not it. I jacked up the bike and removed the fender. I found nothing wrong with the wiring or it's layout. I then removed the left side to inspect it, compare and to jumper from the left side to the right. When I did this, the right side mud flap LED works excellent. My fender tips also worked fine. I check the voltage on the right side leds coming from under the bike and the voltage was 12 volts. It measured the same on the left side. When I checked for resistance there was a large difference between the left side and the right side which seemed very low. I'm not sure if that means anything or not.
Before I remove the Frunk, and start checking any other wires for a grounded lead, I would like to ask if, what I have may be in the lighting or turn signal switch? All other turn signals and lighting seem to be fine. I'm starting to remove hair in large patches, and my wife is starting to question my sanity, (talking to the walls and floors). :yikes:
Any and all suggestions and recommendations would be helpful at this point.
Rod
I think I found the problem
OK, here me out. I have the Street Magic (Fender Tip Conversion), when I removed the lead from the right side wiring, I had a full 12 volts down the wire, (right side), to my fender tips and mud flap lights. Now, I don't have the conversion to turn signals anymore, but now I know what the problem is. Now all I have to do is manufacture another lead to replace the shorted lead. I'll update this thread, if the problem is in fact resolved or any further issues come up. :D
