2 Attachment(s)
I replaced original Saddlebag reflectors using TricLED Red LED Running Light kit
I replaced the original saddlebag reflectors on the saddlebags with the lighted LED reflectors. The kit installed ok, except that my hand really doesn't fit in there where you have to reach in the narrow slot after removing 3 screws and a push-pin as shown in the video. I managed with the help of a long-nose needle pliers with a couple scratch and "ouch that hurts" exclamations (insert your own words here!). But overall not a bad install.
Interesting thing was: the install video noted that I would need an 8mm socket to remove the strap that holds the saddlebag cover when opened. That was true on the right side of the bike. But... on the left side, BRP (I assume, unless the dealer monkeyed with it ... which I doubt) instead of the 8mm socket, it was a torques screw head. Do they just use whatever screw is laying around within reach when they assemble these?
Regardless, I think any added lighting provides additional safety and these lights are VERY bright.
