Has anyone installed netting on the inside of the 2020 RT + saddle bags to secure gear in case the door opens?
No. Mine has the luggage. I always lock the side cases. Never had a problem with them opening unexpectedly.
https://www.motosport.com/product/?a...google&variant[HOP000W]=HOP000W-X001-Y001
Not what you ask for but works well inside the lids. Netting is smaller than you'd think and stretches tight across the lid. Drill few holes, use short machine type screws.
I would like nets for the saddlebag doors to hold smaller loose items. They have them for older models, why not 2020+?
Yes, I installed the ones for the 2010-2019 design RT's. One has to add one or two small screws to the bottom of the lids. Then attach black nylon foldover wire guides at the six screws. Use black electrical wire ties to each location, draw them up fairly tight and cut off the excess . They work Quite well.
I bought the saddlebags from spyder pops and they hold all the gear I want. Everything in its place and nothing to fall out when you open the saddlebag door.
