Testing Signature:
Testing Signature:
Testing Signature 2:
It appears to work.
If you're trying to break the signature content up into two columns spaced across the page instead of one list straight down the page, you might need to insert the contents of that list into a Table.... :dontknow:
I believe that if you do use a Table, it needs to be no more than 500 wide, altho my forgettory's working over-time atm & I can't recall the exact size that's max. :opps:
If you want to tell me where you might like the list split, I can play with it a bit in order to work it out properly & get back to you on how to it?? :dontknow:
Over to you! :cheers:
You must have the ONLY 2012 F3 ...
My Bad, 2015! fixed it.
