Wouldn't you guys like to have a 2020 & up RT category on here ? Since its a totally different machine in every way, it would seem easier to get the right answers and more organized. What's your thoughts ?
Printable View
On one hand it would, but that could also have been said for the 2010-2013 since they have a totally different drivetrain. But I do feel you. With the exception of how to take items off (plastic), it is still largely the same as the other 1330's.
YES.
no matter what motor powered vehicle forum you go on each generation of said vehicle has their own sub forum.
WE MOST DEFINITELY NEED ONE FOR 2020 PLUS CAN AM SPYDER RT-L.
Never thought about it. It may be useful, but would require more work from the hosts/moderators.
It would get rid of the need to tell your year and model, but I don't mind doing that either.
If it happens, cool. If not, still cool.
I agree with having this new forum put up.
Oftentimes I am reading through a whole line of posts only to discover that often people are accidentally, albeit with good intentions, responding with ideas/fixes that relate only to pre-2020 models in some way and therefore not relevant to the specific discussion.
Moderators… thank you for considering this new forum.
I can also compare it to like when you browse for accessory parts, and it doesn't say" fits 2020 and up models" it just creates confusion if it will work or not. But most accessory sites have a separate category just for 20 & up that makes it so much easier to shop. There can be so many benefits to doing this on here.
This moderator is watching. The subject will be discussed. :popcorn:
The problem is, you can’t just create a new category for the ‘20+ models on the Forum. Many members look at “new posts” which incorporates posts from every category, and unless they are switched on enough to check the category, you will still get members trying to be helpful, but posting incorrect information for the wrong model. Plus, you will undoubtedly get posters unaware of the category into which they are posting.
Until everyone starts putting their model/year in their signature (or at least a photo in their profile), and those responding check for the model/year to which the OP is referring, confusion will reign supreme. ;)
Pete
I dont think that point alone could justify not having one at all, there is a bigger need for it than not. There will always be some people, no matter what you do, that just don't read enough into what they respond to. It's like that on every platform no matter how well categorized it is.
But Pete, the right most column of the "What's New" section identifies which forum it came from. When scanning the "new Posts" all one has to do is move your eyes over to that column and you will know it's from the 20+ forum. Thank you for all you do for us Spyder Lovers. :clap:
Hahaha…….you’re not alone, blacklightning:ohyea:. The only reason I knew was that I spent ages trying to find it recently to upgrade the info to my new RT. It’s not really intuitive as you would expect to find it under the heading of “My Profile”, not “Settings” ;):dontknow:
Pete
I agree completely, Valk and Rick, but there are only a few like you who look at the category name on the right. I have to admit that I usually don’t, but I do look closely at the thread to determine the model/year to which the OP is referring, if I am planning on posting a reply. I have absolutely no aversion to having a ‘20+ RT category, but I do feel that it will not alleviate the issue of posters not bothering to ensure they are posting information for the correct model if they are using the “What’s New” option. How you address that is beyond me, unfortunately…….but I am definitely not anti a new category:thumbup:
Pete
The potential problem with adding a new category is it can actually make forum threads harder to find! I've experienced this with my own personal filing system at home and when I had a print shop many years ago. What happens when you have a bunch of neat little categories for filing, you can often not figure out the best category to put the item in. Then when you go look for it you end up scanning through many categories because the item isn't in the category you first think it will be in. Sometimes it's easier to sort through one large pile than several small piles! So an additional category may just increase confusion.
When I had the print shop I ended up creating one folder for each customer's job. Those were filed alphabetically by customer name making them easy to find. To do a print job I made a negative, and then used that negative to make the printing plate. I found the best way to store the negatives and plates was to serialize them and store them numerically. The serial number was then entered into the customer's job folder, which contained the composition of art and type. It worked good most of the time!
I don't necessarily think my method would work here in the forum, but I offer it up to illustrate that keeping items sorted and easily found is not always as easy as it seems it should be.
I agree with the need. The 20+ are as different as 18+ GoldWings from previous 1800s. Should aid both those seeking 20+ info and others seeking older, plus maybe encourage posting only 20+ info and not confusing issues.
4 months since the question has been asked and not addressed.
We need our own sub forum for 2020 +.
Hmm, over 28,000 members; more than 6,000 of them active on the boards & posting regularly; and yet over the last 5 months there's been what, 116 members read this thread but just 6 members posting in here to show that they want a new sub-forum for the latest models... :rolleyes: I can't really see it as a priority - at least not yet! :dontknow:
But I'll give it a bump to see if any more interested members will post up in here anyway. :thumbup:
Just for those claiming this thread should be elsewhere, if this thread wasn't moved to where it was meant to be in the first place, where the owners/operators of the place that you all are using expect to find support requests, then it'd be a REAL indicator that there's absolutely NO POINT in having sections and sub-forums for anything, wouldn't it?! :dontknow: Cos if YOU can just stick whatever you feel like in whatever section or sub-forum you feel like, then surely everyone else should be allowed to do the same, shouldn't they... And THAT would totally remove the need for another sub-forum. :banghead:
You can't have it both ways - either you and everyone else puts things where they should go, including this thread (posts in which btw still appear in the New Posts or Today's Posts searches that the majority of readers use to see what's been added lately) or if you don't bother & don't see a need to do that, then surely no-one else need bother too, and we know that'd mean that there's no point in adding a new sub-forum cos no-one'll use it anyway! :rolleyes:
And THAT is the END of any discussion about where this thread should be! It is EXACTLY where requests of this nature should be. If you want a new sub-forum, post your support, but any arguing about why this thread is here is finished!
I agree there should be a 2020+ RT forum.
Only 6 people made the direct comment but I wouldn’t be surprised if more are in agreement but just don't bother to make a comment to this thread. A good example for needing the split is the seat / trunk strut threads that get all the comments mixed up and leading to confusion for many.
Maybe something as simple a poll when coming on to the SL site for a month to get user feedback would be helpful in making the decision.
+1 on a separate category. I too get lost when pre-2020 owners dominate a thread, and people also posting a reply to someone with a 2020+ saying 'I don't have one, but this works on a 2014...etc."
My $0.02.
