What's the best LED's for rear bulbs and turn signals? 2015 RTS
Wondering what is the best LED bulbs for the rear running/brake bulbs and turn signal bulbs?
I am wiring up a trailer wiring harness and figured if I was going to basically have to take the rear Tupperware off and remove the rear light assemblies, that I might as well update the bulbs while I had them out.
Thanks,
Brent
Brightest turn signals available
Based on the recommendation of another member I installed these https://www.auxito.com/products/7507...ulb-2800-lumen as turn signals https://www.spyderlovers.com/forums/...=1#post1595128 They can ONLY be used as turn signals or else they will overheat and burn out. There's nothing brighter. Similar products by other OEMs can be found on Amazon.
