2013 RT RED lower side panel …not sure but a 2012 may fit as well.
Printable View
Not just the 2012's Tatonka, the appropriate Lower Side Panels off any 2010 - 2013 RT's should fit! :thumbup: . It was only in 2014 that the panel changes to suit the new wider motors came about - up until then the Tupperware body panels were all basically interchangeable regardless of the year, so any of the 2010-2013 model year panels should work for you, even if you do hafta accept a different colour panel initially & get it painted! :ohyea:
Only if you do end up doing that 'get it painted' thing (ie. getting a different coloured panel painted to suit your Spyder! ;) ) make sure you don't just go off the BRP colour code, but instead use that code as a base & get the new paint colour matched to one of the immediately adjacent panels with it's old/faded colour. You'd be amazed at how much 9 or so years of exposure to the sun & weather etc can make a colour like the OE Red fade/change, and it's even worse if you've used any of those ceramic sealer/paint protectorant type products (& yeah, I know I'm using that term 'products' pretty loosely! :p ) it REALLY makes it hard to match the colour, and impossible to get close just using the OE Colour Codes! :banghead:
Good luck finding the panel you're after, Tatonka! :cheers:
Check ebay, you never know, may get lucky!!!
Now Looking for red left-hand lower side panel for RT years 2010 to 2013.
Left lower side panel for viper red 2013 RT.
Try ebay motors. They have quite a lot of body panels.
Yes there has been a 2012 listed for some time….it indicates that it would not fit a 2013 but I’m not so sure about that. I made an offer on it but the seller is very proud of it!
still looking for red left lower side panel for 2013 rt
Finally found the side panel from an out fit that was parting out a red 2012 RT. PETER you were right on…went on perfectly in form fit and color.
If you've got it now & so no longer need this thread, could you please follow the directions in the '***** READ FIRST! - How to Use.....' sticky at the top of the index page (& linked below) to mark the thread as SOLD (yeah, I know it's not strictly 'sold', but it's the only label we've got! :rolleyes: ) and close the thread?
https://www.spyderlovers.com/forums/...sub-forum-****
Glad you finally got the bit you were after. :ohyea: :thumbup:
