I’ve got a funky electrical issue - Ryker won't start after fixing light...
I’m no stranger to auto/motorcycle work, and I’m afraid I know what the answer is, but I figured I’d ask here before taking the next (expensive) steps.
We’ve been installing upgraded lighting on the wife’s 2019 Ryker to help improve visibility, Right side went well, but on the left side, the wiring harness was pinched between the two parts of the fender. I had to rebuild the plug (using identical parts and a new pin, it’s visually and electrically identical to how it was before the work.)
But the bike now has a no-start situation, to the point that I can’t even query for trouble codes:
https://youtu.be/tvG_MvoVIto
The battery tests good, and I’ve used other batteries in place to validate it’s not a poor power issue, and the modified turn signals work correctly (so it’s not a mis-wiring issue, currently)…things like the horn and hazards work correctly, but the system won’t stop the behavior unless I pull the key and toggle the run/stop switch.
I suspect ESD (Electrostatic Discharge) may have taken out the ECU…and that I’ll not be able to troubleshoot without one, but figured I’d ask around before taking those steps.
Thank you for posting this information
Thank you for posting this information, I ran into the same problem.
