Is your spyder shaking, start with the belt tensioner. Now on to Tires!
Why does lowering the belt tension help shaking?
Main question: So, I cannot find any solid laymen's explanation why lowering the belt tension below BRP's stats helps shaking?
I am taking the bike to a local dealership tomorrow morning to have them lower the belt tension some more, but I wanted to talk with ya'll before I do. Am I wasting my time?
Back story: I have posted several things about my issue. So, I have a 2021 F3 Ltd. It shakes at 55+ and does not go away. I've been working on this issue since day 1 of picking the bike up.
I have upgraded the sway bar, shocks, windshield, front tires and belt tensioner.
Recently, I replaced the front Kendas with I have changed to Continental ContiProContact 165/60R-15. The shaking in the bike only eased up a little...I cannot tell much of a difference. Now, when I put my feet on the front fenders at 55-70mph, the fenders still barely bounce. I hardly feel anything within my feet, and the fenders look steady. So, it was NOT the tires.
The overall ride is still bad over 55mph-ish with the shaking starting lightest in my feet up and gets worse up through my body and to my head which can feel like it's buffeting. And, it is not from what little wind is hitting me. The windshield does shake a lot, but it's not the wind...it is shaking from the dash shaking. And, at times the dash shakes to the point where the speakers distort.
Under 55mph, she rides really smooth...then it all begins to turn into shaking and progressively gets worse the higher the mph...never smooths back out...even on the smoothest of black-top. However, I will must point out...the shaking some times does feel to ease up only a little at higher RPM's in 5th gear over 65mph and at times in 6th over 80mph. I realize some of these bikes like to run high within the RPM's...so, I have been trying different riding styles. It is not the riding style...unfortunately.
I have ridden other Spyder models including F3's and the new 2021 stock F3 as well...all ride a lot smother than mine. I realize bikes do shake, but this is just not right.
The day after I got the new tires, I had the dealership lower the belt tension from 242lbs to 220lbs per recommendations from other Spyder riders. It did help smooth her out some, but the ride should be better. The mechanic told me he could feel it as well.
I have read many posts around the net where some lowered their belt tension below 200, and it helped them (to what they consider perfection). I am thinking I may want to lower mine some more.
I am capable of doing it myself and want to learn. The only video I can find https://www.youtube.com/watch?v=0_Ewxr7qwqo shows the rear end of what looks like a GS or ST...but, it looks similar to my 2021 F3 Ltd.
1. Can anyone verify if this video demo https://www.youtube.com/watch?v=0_Ewxr7qwqo for adjusting the belt tension is still possibly one correct method, is the hardest method, etc.?
2. If anyone else has lowered their belt tension due to shaking, please share your belt tension reading and if it helped.
3. If possible...can anyone (in layman’s terms) briefly explain why lowering the belt tension would smooth out shaking on some bikes. It seems to me the looser the belt, the rougher the ride.
4. Note belt related sorta...but, is there supposed to be a cotter pin where the large bolt attaches to the rear axle? Mine does not as shown in the video. It seems like a safety thing, and I should have one...but, a dealer told me it was not necessary.
If I did not already mention this...I do have a SpyderExtras belt tensioner.
Also, about a month ago, BRP closed out my ticket the original dealership opened due to the aftermarket items on my bike and everything being up-to-spec. So, I am really on my own now...
I am trying really hard to remain optimistic she will ride as expected at some point.
