Originally Posted by
Rednaxs60
Had to do some thinking on this one. Suspension is an interesting subject. I have been looking for information on setting up a Spyder suspension because I have a set of M2 shocks, front/rear, coming for my '14 RT LE.
Shocks can have preload, rebound and compression settings. Preload is the simplest to understand, adjust ride height and sag. Preload does not change the shock spring rate. Preload should be set such that the primary ride height based on solo/two up percentages, is kept to a minimum - as close to no preload as possible. Rebound is how fast/slow the shock returns to it's resting/riding condition, compression similar - how fast/slow the shock compresses when hitting a bump.
To get a better ride quality, you actually need to have a shock with preload, rebound/compression settings, preferably preload and rebound, and the appropriate spring rate. You can get the all singing, all dancing ones but for recreational riding not required - preload and rebound is good. Shock spring rate should be for the primary riding scenario solo/two up.
If you have to have a lot of preload to achieve the desired ride height, shock spring rate is too soft, conversely, if the ride is too harsh with no preload, too stiff a spring rate. Without a rebound setting, how the shock returns to the ride height position is a matter of internal shock design. This may sound like the spring rate changes depending on the preload adjustment, but it does not.
I have just installed a new set of Hagon shocks on my '85 Honda Goldwing Limited Edition that has preload and rebound adjustments. The rebound adjuster is a combined rebound/compression adjustment of 70/30.
You lightened the preload, reducing the ride height, probably not that much, but enough to change how the Spyder reacted in the corner. The taller the Spyder front end the more cornering force required to get the side opposite to the corner, left turn - right side/right turn - left side, down far enough to get the inside wheel off the ground. The less taller the ride height, the less the cornering force required to get the inside wheel off the ground.
What happened to you in a corner could also indicate that the shock may be past the best before date - shocks do wear out without any external visible indication.
Put the preload back to where it was. Measure the distance of the front of the Spyder from the ground when you do this. I've read that it should be in the 4-5 inch range. Anytime you do a preload adjustment, check the front height, same with the rear.
Bajaron's sway bar upgrade is a good start - does reduce sway in the corner, but if you are going to keep the Spyder, consider a shock upgrade as well. The OEM shocks that are on your Spyder are 11 years old, were designed to meet the requirements of a wide range of riders, and additional weight, but not to last forever. We tend to disregard this aspect when owning a vehicle because we grow with the suspension degradation, and think all is well.
Hope this helps. Good luck
