T 45 Question about Oil Drain Plug
Hello I have a question on the T45 plug I’ve never changed the oil on my 2016 RTL only because the dealer thru in a 2 yr free service when I bought it in 2018. My question is I’m leaking oil I thought it might be from the oil change but it’s still dripping so I did some checking and noticed that the plug was oily. Ok I put a T45 on a short extension and I notice it was crooked (at an angle when in)not straight up and down as I would have thought. I’m sure it’s the T45 a 6mm doesn’t seem to fit. Anyhow is that normal to be at an angle or should it be straight up and down for you that have changed your oil on the 1330. I’m due back at the dealers Saturday but I think they cross threaded that drain plug. Thanks for any answers. And this isn’t the first time the dealer did an oil change on my Spyder. Thanks Michrick
1 Attachment(s)
First and Last Dealer Oil Change
I found a Torx Bit Driven into the Allen Head Drain Plug.
